ovi40_displaybuild [14.01.2018 23:07] – df9ts | ovi40build:ovi40_displaybuild [17.01.2018 10:56] – [Displayboard auf UI Board befestigen] df9ts_user | ||
Zeile 15: | Zeile 43: | ||
- | Jetzt habe ich 60mA | ||
- | ==== Bestückung ==== | ||
Zeile 44: | Zeile 63: | ||
Weil der " | Weil der " | ||
+ | Als temporäre Lösung | ||
- | yes - your shipment | + | I have other options which are already available (lcd board was designed to this): |
- | And it is only connection between LCD FPC connector SDO and pin12 / SDO. | + | 1. Use a plastic hex shape spacer with external/ |
- | If pin12 is no longer connected | + | https://www.tme.eu/ |
+ | by putting the externally threaded part of it into available 3mm hole in lcd board, cut out the excess | ||
+ | Yes- in the future revisions of UI we should have two 3mm holes to lcd screwing, | ||
- | (14Jan18 23:49) | + | 2. Use a plastic hex shape spacer with both internal threads like this one: |
+ | and screw it to lcd with PEM FH flat bolt like this (more " |
