ovi40_displaybuild [14.01.2018 23:07] – df9ts | ovi40build:displaybuild [17.01.2018 12:51] – [Display Kalibrierung - wichtig!] df9ts_user | ||
Zeile 15: | Zeile 45: | ||
- | Jetzt habe ich 60mA | ||
- | ==== Bestückung ==== | ||
Zeile 44: | Zeile 65: | ||
Weil der " | Weil der " | ||
- | I think I got LCD's with the SDO line still connected as there is no cutting visible | + | < |
+ | 1. Use a plastic hex shape spacer | ||
+ | by putting | ||
- | (14Jan18 23:49) |
