ovi40_displaybuild [14.01.2018 23:18] – df9ts | ovi40build:ovi40_displaybuild [17.01.2018 10:56] – [Displayboard auf UI Board befestigen] df9ts_user | ||
Zeile 12: | Zeile 26: | ||
Zeile 50: | Zeile 63: | ||
Weil der " | Weil der " | ||
- | (14Jan18 23:49) | + | 2. Use a plastic hex shape spacer with both internal threads like this one: |
+ | and screw it to lcd with PEM FH flat bolt like this (more " |
