ovi40_displaybuild [15.01.2018 10:09] – [Unterbechung der SDO Leitung] df9ts | ovi40_displaybuild [15.01.2018 15:30] – df9ts | ||
+ | * 3.5" Display (OVI40 Standard) | ||
+ | * 3.2" Display (während des UI Betatests benutzt) | ||
+ | * 2.5" Display (mcHF Standard) | ||
Zeile 12: | Zeile 20: | ||
- | Cut the track which is shown in the following picture. It is the "data output" | + | Die im folgenden Bild gezeigte Unterbrechung durchführen. Es handelt sich um die SPI SDO "data output" |
- | I have already modified all LCD PCBs which are shipped after 01/ | + | |
Zeile 56: | Zeile 58: | ||
