ovi40_displaybuild [15.01.2018 10:09] – [Unterbechung der SDO Leitung] df9ts | ovi40_displaybuild [16.01.2018 11:35] – df9ts | ||
+ | ==== Display Kalibrierung ==== | ||
Zeile 12: | Zeile 26: | ||
- | Cut the track which is shown in the following picture. It is the "data output" | + | Die im folgenden Bild gezeigte Unterbrechung durchführen. Es handelt sich um die SPI SDO "data output" |
- | I have already modified all LCD PCBs which are shipped after 01/ | + | |
Zeile 56: | Zeile 64: | ||
