ovi40_displaybuild [15.01.2018 15:30] – df9ts | ovi40_displaybuild [16.01.2018 11:35] – df9ts | ||
Zeile 4: | Zeile 4: | ||
- | * 3.5" Display (OVI40 Standard) | + | * 3.5" Display |
- | * 3.2" Display (während des UI Betatests benutzt) | + | * 3.2" Display |
- | * 2.5" Display (mcHF Standard) | + | * 2.8" Display |
+ | ==== Display Kalibrierung ==== | ||
==== Display Helligkeit ==== | ==== Display Helligkeit ==== |
