ovi40_displaybuild [16.01.2018 07:52] – df9ts | ovi40build:displaybuild [17.01.2018 12:48] – df9ts_user | ||
- | * 3.5" Display (OVI40 Standard) | + | * 3.5" Display |
- | * 3.2" Display (während des UI Betatests benutzt) | + | * 3.2" Display |
- | * 2.8" Display (mcHF Standard) | + | * 2.8" Display |
Zeile 56: | Zeile 63: | ||
Weil der " | Weil der " | ||
- | (15Jan18 11:00) |
