ovi40_displaybuild [16.01.2018 10:30] – df9ts | ovi40build:ovi40_displaybuild [17.01.2018 10:56] – [Displayboard auf UI Board befestigen] df9ts_user | ||
Zeile 10: | Zeile 10: | ||
- | < | + | Die Touchscreen |
Zeile 60: | Zeile 63: | ||
Weil der " | Weil der " | ||
- | (15Jan18 11:00) | + | 2. Use a plastic hex shape spacer with both internal threads like this one: |
+ | and screw it to lcd with PEM FH flat bolt like this (more " |
