ovi40_displaybuild [16.01.2018 10:30] – df9ts | ovi40build:displaybuild [17.01.2018 12:47] – [Display Platine] df9ts_user | ||
Zeile 8: | Zeile 8: | ||
+ | | 95% 50% 50% | | ||
- | < | + | Die Touchscreen |
Zeile 59: | Zeile 63: | ||
Weil der " | Weil der " | ||
- | (15Jan18 11:00) |
