ovi40build:ovi40_displaybuild [17.01.2018 08:20] – [Schnittstelle LCD und Display Kontroller] df9ts | ovi40build:ovi40_displaybuild [17.01.2018 11:04] – [Displayboard auf UI Board befestigen] df9ts_user | ||
Zeile 69: | Zeile 69: | ||
- | ==== Schnittstelle LCD und Display Kontroller ==== | + | I have other options which are already available (lcd board was designed to this): |
- | Zur Information und als Unterlage zur Fehlersuche: | + | 1. Use a plastic hex shape spacer with external/ |
- | [{{: | + | https:// |
- | [{{: | + | by putting the externally threaded part of it into available 3mm hole in lcd board, cut out the excess and simply glue it to the pcb. |
