ovi40build:ovi40_displaybuild [17.01.2018 11:04] – [Displayboard auf UI Board befestigen] df9ts_user | ovi40build:displaybuild [17.01.2018 18:01] – df9ts | ||
Zeile 8: | Zeile 11: | ||
+ | [[https:// | ||
Zeile 43: | Zeile 66: | ||
- | Und das LCD läuft zur Zeit sowohl | + | |
- | Weil der " | + | |
- | I have other options which are already available (lcd board was designed to this): | + | |
- | https:// | + | |
- | |< 95% 50% 50% >| | + | |
