ovi40build:displaybuild [17.01.2018 12:48] – df9ts_user | ovi40build:displaybuild [17.01.2018 13:15] – df9ts_user | ||
Zeile 8: | Zeile 8: | ||
- | |< 95% 50% 50% >| | + | |< 95% 50% 50% >| |
Zeile 44: | Zeile 45: | ||
- | Weil der " | + | |
- | < | + | Als temporäre Lösung - bis ein OVI40 Gehäuse |
- | Als temporäre Lösung - bis Gehäuse | + | |
- | --- | + | Alternativ können Plastik-Abstandshalter verwendet werden: |
- | I have other options which are already available (lcd board was designed to this): | + | **Option |
- | 1. Use a plastic hex shape spacer with external/ | + | https:// |
- | https:// | + | |
- | 2. Use a plastic hex shape spacer with both internal threads like this one: | + | **Option |
- | https:// | + | [[https:// |
