ovi40build:displaybuild [17.01.2018 12:48] – [Display Platine] df9ts_user | ovi40build:displaybuild [17.01.2018 13:13] – df9ts_user | ||
Zeile 12: | Zeile 12: | ||
Zeile 44: | Zeile 45: | ||
- | Weil der " | + | |
- | < | + | Als temporäre Lösung - bis Gehäuse vorhanden sind - wird vorgeschlagen, |
- | --- | + | Alternativ können Plastik-Abstandshalter verwendet werden |
- | I have other options which are already available (lcd board was designed to this): | + | **Option |
- | 1. Use a plastic hex shape spacer with external/ | + | https:// |
- | https:// | + | |
- | 2. Use a plastic hex shape spacer with both internal threads like this one: | + | **Option |
- | https:// | + | [[https:// |
