ovi40_uiboardbuild [16.01.2018 12:15] – df9ts | ovi40build:uiboardbuild [25.01.2018 15:50] – df9ts | ||
- | ==== IVI40 UI Board ==== | + | ===== Building the UI V1.8 Board ===== |
- | Auf das UI Board werden Displayboard und RFboard direkt aufgesteckt (Pfostensteckverbinder) | + | ==== OVI40 UI V1.7 Documents ==== |
- | ==== OVI40 V1.8 Bausatz ==== | + | **UI V1.7 documents are provided for information only**. Please primarily use the V1.8 documents for building the UI V1.8 board. |
- | {{ : | + | Please note that the component placement docs are searchable pdf documents. During soldering they can be used to quickly find a component' |
- | ==== Aufbauhinweise | + | ==== OVI40 UI V1.8 Documents |
- | < | + | ==== OVI40 UI V1.8 Kit Contents ==== |
- | OVI40 UI V1.7 Schaltbild: {{: | + | The kit contains |
+ | |[{{:projekte: | ||
- | OVI40 UI PCB top layer: {{: | + | ==== Assembly and Soldering ==== |
- | ==== Unterlagen: OVI40 UI V1.8 ==== | + | The graphics below - UI V1.7 with 3.2" Display - give an impression on how the finished |
- | OVI40 UI BoM: [[: | + | |< 95% 50% 50% >| |
- | BoM von F4HTX Francois mit Bauteiletütchen Nummern: | + | | [{{:ovi40build:ui_top_3d.png?400|UI Board V1.7 mit 3.2" Display)}}] |
- | ==== STM32F76X_ZIT vs. STM32H743ZIT6 | + | === Please read Errata carefully |
- | ==== Flashen des UI Boards ==== | + | Make sure to read the [[:ovi40build: |
- | Weiter Details sind hier erklärt: https:// | + | < |
+ | === IC Device Markings === | ||
+ | </code> | ||
- | < | + | The smaller ICs can be identified by device mark. The following device marks are used: |
- | === Bootloader laden === | + | |< 45% 25% 25% 25% 25% >| |
- | Stromversorgung dazu 5 Volt Pin 28+ , Pin 30 Gnd) | + | |Typ |Device Mark |Schematic |
+ | |LP5907_Q1 | ||
+ | |BAV70 | ||
+ | |BC857B | ||
+ | |BAS85 | ||
- | === UHSDR Firmware laden === | + | === MCU STM32 "Pin 1" marking |
- | - +8V on JP1 pin 29 - zur Stromversorgung des USB stick! | + | Please understand the correct orientation of STM32 MCU Pin 1. There are two markings on the IC. Please not the text printed on MCU to find the correct Pin 1: When reading the text Pin 1 is on bottom left corner. |
- | - +5V on JP1 pin 28 legen - um bootloader zu starten | + | [{{: |
- | - USB stick in USB port stecken | + | |
- | - Warten bis FW upload fertig ist | + | < |
- | | + | === STM32F76X_ZIT vs. STM32H743ZIT6 === |
- | - +5V aus und wieder einschalten für OVI40 UI board reboot. | + | </ |
+ | The kit is shipped with STM32F76X_ZIT | ||
+ | Comparison of MCUs: | ||
+ | |Flash[kB] | ||
+ | |Clock[MHz] | ||
+ | |FPU |single | ||
+ | |DMIPS | ||
+ | === EEPROM IC7 orientation === | ||
+ | === Prevent short cut with back up battery holder === | ||
+ | One of the connection pins of the battery holder might touch ground connection of a rotary encoder. Make sure to cut this pin flush with PCB surface **before soldering** | ||
+ | ==== Modifications ==== | ||
+ | Symptom: In stand-by the current drawn from back-up battery is excessively high. Work-around: | ||
