Nächste Überarbeitung | Vorhergehende Überarbeitung Nächste ÜberarbeitungBeide Seiten der Revision | ||
ovi40build:uiboardbuild [17.01.2018 15:38] – df9ts_user | ovi40build:uiboardbuild [25.01.2018 15:50] – df9ts | ||
- | ==== IVI40 UI Board ==== | + | ===== Building the UI V1.8 Board ===== |
- | Auf das UI Board werden Displayboard und RFboard direkt aufgesteckt (Pfostensteckverbinder) | + | ==== OVI40 UI V1.7 Documents ==== |
- | ==== OVI40 V1.8 Bausatzinhalt ==== | + | **UI V1.7 documents are provided for information only**. Please primarily use the V1.8 documents for building the UI V1.8 board. |
- | ==== Aufbauhinweise ==== | + | Please note that the component placement docs are searchable pdf documents. During soldering they can be used to quickly find a component' |
- | ==== Unterlagen: | + | ==== OVI40 UI V1.8 Documents |
+ | * {{:projekte: | ||
- | OVI40 UI V1.7 Schaltbild: {{: | + | ==== OVI40 UI V1.8 Kit Contents ==== |
- | OVI40 UI PCB bottom layer: {{: | + | The kit contains |
+ | |[{{:projekte: | ||
- | ==== Unterlagen: OVI40 UI V1.8 ==== | + | ==== Assembly and Soldering |
- | OVI40 UI BoM: [[: | + | The graphics below - UI V1.7 with 3.2" Display |
- | ==== STM32F76X_ZIT vs. STM32H743ZIT6 ==== | + | | [{{: |
- | Die H7 - MCU wird zukünftig der Standard sein, die F7 MCU wird "forever" | + | |
- | ==== Die UI-Platine in Betrieb nehmen | + | === Please read Errata carefully |
- | //dfu-util -l//\\ | + | |
- | Bootloader: //dfu-util -d -R -a 0 0483:df11 -D Pfad-zur/ | + | Make sure to read the [[:ovi40build:batch1uiboarderrata|Errata]] carefully **before starting assembly.** |
- | Firmware: //dfu-util -d -R -a 0 0483:df11 -D Pfad-zur/fw-40SDR.dfu// | + | < |
+ | === IC Device Markings === | ||
+ | The smaller ICs can be identified by device mark. The following device marks are used: | ||
+ | |LP5907_Q1 | ||
+ | |BAV70 | ||
+ | |BC857B | ||
+ | |BAS85 | ||
+ | === MCU STM32 "Pin 1" marking === | ||
+ | Please understand the correct orientation of STM32 MCU Pin 1. There are two markings on the IC. Please not the text printed on MCU to find the correct Pin 1: When reading the text Pin 1 is on bottom left corner. | ||
+ | </code> | ||
+ | The kit is shipped with STM32F76X_ZIT (" | ||
+ | Comparison of MCUs: | ||
+ | |Flash[kB] | ||
+ | |Clock[MHz] | ||
+ | |FPU |single | ||
+ | |DMIPS | ||
+ | === EEPROM IC7 orientation === | ||
+ | === Prevent short cut with back up battery holder === | ||
+ | One of the connection pins of the battery holder might touch ground connection of a rotary encoder. Make sure to cut this pin flush with PCB surface **before soldering** | ||
+ | * "mcHF style": | ||
+ | * "OVI40 style": | ||
+ | ==== Modifications ==== | ||
+ | Symptom: In stand-by the current drawn from back-up battery is excessively high. Work-around: | ||
- | [[https:// | ||
