ovi40build:uiboardbuild [17.01.2018 15:38] – df9ts_user | ovi40build:uiboardbuild [25.01.2018 16:01] – df9ts | ||
- | ==== OVI40 V1.8 Bausatzinhalt ==== | + | **UI V1.7 documents sind nur zur Information**. Bitte benutzt |
- | ==== Aufbauhinweise ==== | + | Die PDFs " |
+ | * {{:projekte: | ||
+ | |[{{:projekte: | ||
- | BoM von F4HTX Francois mit Bauteiletütchen Nummern: | + | |< 95% 50% 50% >| |
+ | | [{{:ovi40build:ui_top_3d.png?400|UI Board V1.7 mit 3.2" Display)}}] | ||
- | ==== STM32F76X_ZIT vs. STM32H743ZIT6 | + | === Bitte zuerst sorgfältig die Errata lesen! |
- | ==== Die UI-Platine in Betrieb nehmen ==== | + | Wichtig: zuerst |
- | //dfu-util -l//\\ | + | |
- | Bootloader: //dfu-util -d -R -a 0 0483:df11 -D Pfad-zur/ | + | === IC Device Markings === |
- | Firmware: //dfu-util -d -R -a 0 0483:df11 -D Pfad-zur/fw-40SDR.dfu// | + | The smaller ICs can be identified by device mark. The following device marks are used: |
+ | |LP5907_Q1 | ||
+ | |BAV70 | ||
+ | |BC857B | ||
+ | |BAS85 | ||
+ | === MCU STM32 "Pin 1" marking === | ||
+ | Please understand the correct orientation of STM32 MCU Pin 1. There are two markings on the IC. Please not the text printed on MCU to find the correct Pin 1: When reading the text Pin 1 is on bottom left corner. | ||
+ | </code> | ||
+ | The kit is shipped with STM32F76X_ZIT (" | ||
+ | Comparison of MCUs: | ||
+ | |Flash[kB] | ||
+ | |Clock[MHz] | ||
+ | |FPU |single | ||
+ | |DMIPS | ||
+ | === EEPROM IC7 orientation === | ||
+ | === Prevent short cut with back up battery holder === | ||
+ | One of the connection pins of the battery holder might touch ground connection of a rotary encoder. Make sure to cut this pin flush with PCB surface **before soldering** | ||
+ | * "mcHF style": | ||
+ | * "OVI40 style": | ||
+ | ==== Modifications ==== | ||
+ | Symptom: In stand-by the current drawn from back-up battery is excessively high. Work-around: | ||
- | [[https:// | ||
