ovi40build:uiboardbuild [23.01.2018 09:54] – df9ts | ovi40build:uiboardbuild [25.01.2018 15:50] – df9ts | ||
- | Auf das UI Board werden Displayboard und RFboard direkt aufgesteckt (Pfostensteckverbinder) | + | ===== Building the UI V1.8 Board ===== |
- | ==== OVI40 V1.8 Bausatzinhalt | + | ==== OVI40 UI V1.7 Documents |
- | |[{{: | + | **UI V1.7 documents are provided for information only**. Please primarily use the V1.8 documents for building the UI V1.8 board. |
- | |LP5907_Q1 | + | |
- | |BC857B | + | |
- | |BAS85 | + | |
+ | Please note that the component placement docs are searchable pdf documents. During soldering they can be used to quickly find a component' | ||
- | ==== Aufbauhinweise | + | ==== OVI40 UI V1.8 Documents |
- | === UI Board Bestückung | + | * {{: |
+ | ==== OVI40 UI V1.8 Kit Contents | ||
+ | The kit contains UI V1.8 PCB, components in bags and packing list. The display is delivered as assembled and tested unit. | ||
+ | |< 60% 33% 33% 33% >| | ||
+ | ==== Assembly and Soldering ==== | ||
+ | The graphics below - UI V1.7 with 3.2" Display - give an impression on how the finished V1.8 UI board will look like: | ||
+ | === Please read Errata carefully === | ||
- | === Taster S7 und S8 === | + | Make sure to read the [[:ovi40build: |
- | ==== Unterlagen: OVI40 UI V1.7 ==== | + | < |
- | < | + | The smaller ICs can be identified by device mark. The following device marks are used: |
- | OVI40 UI V1.7 Schaltbild: {{: | + | |< 45% 25% 25% 25% 25% >| |
- | OVI40 UI PCB bottom layer: {{: | + | |Typ |Device Mark |Schematic |
+ | |LP5907_Q1 | ||
+ | |BAV70 | ||
+ | |BC857B | ||
+ | |BAS85 | ||
- | OVI40 UI PCB top layer: {{: | + | === MCU STM32 "Pin 1" marking === |
- | ==== Unterlagen: OVI40 UI V1.8 ==== | + | Please understand the correct orientation of STM32 MCU Pin 1. There are two markings on the IC. Please not the text printed on MCU to find the correct Pin 1: When reading the text Pin 1 is on bottom left corner. |
- | BoM von F4HTX Francois mit Bauteiletütchen Nummern: {{ : | + | < |
- | ==== STM32F76X_ZIT | + | The kit is shipped with STM32F76X_ZIT |
- | Die H7 - MCU wird zukünftig der Standard sein, die F7 MCU wird " | + | Comparison of MCUs: |
- | |Flash[kB] | ||
- | |Takt[MHz] | ||
- | |FPU |single | ||
- | |Pins | ||
- | |DMIPS | ||
- | ==== Die UI-Platine in Betrieb nehmen ==== | + | | |
- | Die UI-Platine kann (und sollte) ohne die RF-Platine zum ersten Mal in Betrieb genommen werden. Lasst das LCD zunächst weg, Jumper P6 wird gesteckt. An Pin 30 des oberen Headers wird Masse gelegt, an Pin28 +5V. Die Stromaufnahme in diesem Zustand liegt deutlich unter 80mA. Wenn nicht: Betriebsspannung sofort wieder trennen und Fehler suchen! Wenn alles ok ist, verbindet ihr die kleine USB-Buchse mit einem PC. Dieser sollte eine neue Hardwarekomponente finden | + | | |
+ | |Clock[MHz] | ||
+ | |FPU |single | ||
+ | |DMIPS | ||
+ | === EEPROM IC7 orientation | ||
+ | === Prevent short cut with back up battery holder === | ||
+ | One of the connection pins of the battery holder might touch ground connection of a rotary encoder. Make sure to cut this pin flush with PCB surface **before soldering** | ||
+ | Please observe mounting orientation of tantal and electrolytic capacitors. Markings on the capacitors are explained [[http://elektroniktutor.de/bauteilkunde/c_smdcod.html|http:// | ||
+ | * "mcHF style": | ||
+ | * "OVI40 style": | ||
+ | ==== Modifications ==== | ||
+ | Symptom: In stand-by the current drawn from back-up battery is excessively high. Work-around: | ||
+ | Helle LEDS: Mit den Bausatz-Vorwiderständen leuchten | ||
- | [[https:// | ||
