ovi40build:uiboardbuild [25.01.2018 16:09] – df9ts | ovi40build:uiboardbuild [25.01.2018 20:44] – df9ts | ||
Zeile 5: | Zeile 5: | ||
Zeile 24: | Zeile 24: | ||
Zeile 31: | Zeile 32: | ||
Zeile 42: | Zeile 44: | ||
|LP5907_Q1 | |LP5907_Q1 | ||
Zeile 56: | Zeile 59: | ||
Vergleich derMCUs: | Vergleich derMCUs: | ||
Zeile 71: | Zeile 74: | ||
|DMIPS | |DMIPS | ||
- | === EEPROM IC7 orientation | + | === EEPROM IC7 Orientierung |
- | This is where the dot is printed. Also the edge of the case is slanted near the 1-4 pins. See [[http:// | + | Auf dem Photo ist der "Pin 1" Punkt klar zu sehen. Die IC Seite mit den Pins 1..4 ist ausserdem leicht abgeschrägt. Siehe auch [[http:// |
- | === Prevent short cut with back up battery holder | + | === Kurzschluß am Batterie-Halter vermeiden |
- | One of the connection pins of the battery holder might touch ground connection of a rotary encoder. Make sure to cut this pin flush with PCB surface **before soldering** | + | === Elkos und Tantals === |
- | [{{:projekte:ovi40-sdr:batt_halter.jpg? | + | === Einbau der Schalter S7 und S8 === |
+ | * "mcHF style": S7 und S8 **nicht** in einer Linie mit den Funktionstasten unter dem LCD, sondern etwas erhöht | ||
+ | * "OVI40 style": S7 and S8 in einer Linie mit den Funktionstasten unterhalb des LCD | ||
- | === Polarised capacitors === | + | "In line" / "OVI40 Style" wird empfohlen. |
- | Please observe mounting orientation of tantal and electrolytic capacitors. Markings on the capacitors are explained [[http:// | + | ==== Modifikationen ==== |
- | === Mounting locations of switches S7 and S8 === | + | === Provisorische Modifikation: Widerstand |
- | + | Symptom: | |
- | Two different mounting locations are provided on the UI PCB for S7 and S8: | + | \\ |
- | * "mcHF style": | + | |
- | * "OVI40 style": | + | |
- | "In line" is the preferred mounting location for S7 and S8. | + | |
- | ==== Modifications ==== | + | |
- | === Temporary Modification: Resistor in parallel | + | |
- | Symptom: | + | |
- | === Change brightness of LEDs === | + | |
Zeile 109: | Zeile 108: | ||
