ovi40build:uiboardbuild [25.01.2018 16:09] – df9ts | ovi40build:uiboardbuild [27.01.2018 06:53] – df9ts_user | ||
- | {{tag>review}} | + | {{tag>publish}} |
Zeile 5: | Zeile 5: | ||
Zeile 24: | Zeile 24: | ||
Zeile 31: | Zeile 32: | ||
Zeile 42: | Zeile 44: | ||
|LP5907_Q1 | |LP5907_Q1 | ||
Zeile 56: | Zeile 59: | ||
Vergleich derMCUs: | Vergleich derMCUs: | ||
Zeile 71: | Zeile 74: | ||
|DMIPS | |DMIPS | ||
- | === EEPROM IC7 orientation | + | === EEPROM IC7 Orientierung |
- | This is where the dot is printed. Also the edge of the case is slanted near the 1-4 pins. See [[http:// | + | Auf dem Photo ist der "Pin 1" Punkt klar zu sehen. Die IC Seite mit den Pins 1..4 ist ausserdem leicht abgeschrägt. Siehe auch [[http:// |
- | === Prevent short cut with back up battery holder | + | === Kurzschluß am Batterie-Halter vermeiden |
- | One of the connection pins of the battery holder might touch ground connection of a rotary encoder. Make sure to cut this pin flush with PCB surface **before soldering** | + | [{{: |
- | === Polarised capacitors | + | === Elkos und Tantals |
- | Please observe mounting orientation of tantal and electrolytic capacitors. Markings on the capacitors are explained [[http:// | ||
- | === Mounting locations of switches | + | === Einbau der Schalter |
+ | * "mcHF style": | ||
+ | * "OVI40 style": | ||
- | Two different mounting locations are provided on the UI PCB for S7 and S8: | + | "In line" / "OVI40 Style" wird empfohlen. |
- | * "mcHF style": | + | ==== Modifikationen ==== |
- | * "OVI40 style": | + | |
- | "In line" is the preferred mounting location for S7 and S8. | + | === Provisorische Modifikation: |
- | ==== Modifications ==== | ||
- | === Temporary Modification: | ||
- | Symptom: In stand-by the current drawn from back-up battery is excessively high. Work-around: | ||
- | === Change brightness of LEDs === | ||
Zeile 109: | Zeile 109: | ||
