ovi40build:uiboardbuild [25.01.2018 20:39] – df9ts | ovi40build:uiboardbuild [19.02.2018 18:16] – df9ts | ||
Zeile 11: | Zeile 11: | ||
Zeile 38: | Zeile 42: | ||
Zeile 53: | Zeile 56: | ||
Zeile 59: | Zeile 62: | ||
Zeile 80: | Zeile 83: | ||
+ | * "mcHF style": | ||
+ | === STM32F76xxx === | ||
+ | 0x111: STM32F767 and STM32F777 LQFP208 and TFBGA216 package | ||
+ | 0x110: STM32F769 and STM32F779 LQFP208 and TFBGA216 package | ||
+ | 0x101: STM32F767 and STM32F777 LQFP176 package | ||
+ | 0x100: STM32F769 and STM32F779 LQFP176 package | ||
+ | 0x011: WLCSP180 package | ||
+ | 0x010: LQFP144 package | ||
+ | 0x001: LQFP100 package | ||
+ | 0x000: Reserved | ||
+ | 0000: LQFP100 (STM32H7x3) | ||
+ | 0010: TQFP144 (STM32H7x3) | ||
+ | 0101: TQFP176/ | ||
+ | 1000: LQFP208/ | ||
Zeile 92: | Zeile 130: | ||
Zeile 102: | Zeile 140: | ||
