ovi40build:uiboardbuild [25.01.2018 20:39] – df9ts | ovi40build:uiboardbuild [21.03.2018 08:44] – [Zusammenbau und Bestückung] dg8ygw | ||
Zeile 11: | Zeile 11: | ||
Zeile 33: | Zeile 37: | ||
Zeile 53: | Zeile 56: | ||
Zeile 59: | Zeile 62: | ||
Zeile 73: | Zeile 76: | ||
|DMIPS | |DMIPS | ||
Zeile 80: | Zeile 85: | ||
+ | * "mcHF style": | ||
+ | === STM32F4 === | ||
+ | === STM32F76xxx === | ||
+ | * 0x000: Reserved | ||
+ | * 0101: TQFP176/ | ||
+ | * 1000: LQFP208/ | ||
Zeile 92: | Zeile 141: | ||
Zeile 102: | Zeile 151: | ||
