ovi40_uiboardtest [14.01.2018 22:31] – df9ts | ovi40_uiboardtest [15.01.2018 10:43] – [Flashen des UI Boards] df9ts | ||
==== Flashen des UI Boards ==== | ==== Flashen des UI Boards ==== | ||
- | STM bootloader geflasht, ebenfalls die Firmware über Dfu (mit 5 Volt Pin 28+ 30 Gnd) | + | === Bootloader laden === |
+ | Siehe auch [[https:// | ||
- | ==== UI Board Test & Fehlersuche ==== | + | Stromversorgung dazu 5 Volt Pin 28+ , Pin 30 Gnd) |
+ | === UHSDR Firmware laden === | ||
+ | Nachdem im DFU mode (J6) der neueste Bootloader geladen wurde (bl-40SDR.dfu): | ||
+ | - +8V on JP1 pin 29 - to power the USB stick! | ||
+ | - Press and hold! BAND - | ||
+ | - +5V on JP1 pin 28 - to envoke bootloader | ||
+ | - Put USB stick into USB port - with the appropriate name of FW (fw-40SDR.bin) | ||
+ | - Wait for it to finish FW upload | ||
+ | - Release the BAND - | ||
+ | - Power cycle +5V | ||
+ | ==== UI Board Test & Fehlersuche ==== | ||
+ | die MCU hat zwei (!) Pin 1 Markierungen | ||
Im falle von fehlendem Audio out: just in case, please check the SW_12V connection. This is power supply connector for Audio power amplifier stage unlike the mcHF. | Im falle von fehlendem Audio out: just in case, please check the SW_12V connection. This is power supply connector for Audio power amplifier stage unlike the mcHF. |
