ovi40_uiboardtest [14.01.2018 22:31] – df9ts | ovi40test:uiboardtest [20.01.2018 11:06] – df9ts | ||
- | ==== Flashen des UI Boards | + | {{tag> |
- | + | ===== UI Board Test & Fehlersuche ===== | |
- | STM bootloader geflasht, ebenfalls die Firmware über Dfu (mit 5 Volt Pin 28+ 30 Gnd) | + | ==== Achtung: MCU Pin1 Markierung |
- | + | die MCU hat zwei (!) Pin 1 Markierungen | |
Im falle von fehlendem Audio out: just in case, please check the SW_12V connection. This is power supply connector for Audio power amplifier stage unlike the mcHF. | Im falle von fehlendem Audio out: just in case, please check the SW_12V connection. This is power supply connector for Audio power amplifier stage unlike the mcHF. |
