ovi40_uiboardtest [14.01.2018 22:31] – df9ts | ovi40test:uiboardtest [03.02.2018 16:40] – Forum Post Troubleshooting eingebaut df9ts_user | ||
- | ==== Flashen des UI Boards | + | {{tag> |
- | STM bootloader geflasht, ebenfalls die Firmware über Dfu (mit 5 Volt Pin 28+ 30 Gnd) | + | ==== EEPROM IC7 Einbau Lage ==== |
- | ==== UI Board Test & Fehlersuche ==== | + | This is where the dot is printed. Also the edge of the case is slanted near the 1-4 pins. See [[http:// |
+ | die MCU hat zwei (!) Pin 1 Markierungen | ||
Im falle von fehlendem Audio out: just in case, please check the SW_12V connection. This is power supply connector for Audio power amplifier stage unlike the mcHF. | Im falle von fehlendem Audio out: just in case, please check the SW_12V connection. This is power supply connector for Audio power amplifier stage unlike the mcHF. | ||
Zeile 23: | Zeile 29: | ||
