ovi40_uiboardtest [14.01.2018 22:32] – df9ts | ovi40_uiboardtest [16.01.2018 11:41] – df9ts | ||
- | ==== Flashen des UI Boards ==== | ||
- | STM bootloader geflasht, ebenfalls die Firmware über Dfu (mit 5 Volt Pin 28+ 30 Gnd) | ||
==== UI Board Test & Fehlersuche ==== | ==== UI Board Test & Fehlersuche ==== | ||
Zeile 10: | Zeile 8: | ||
Im falle von fehlendem Audio out: just in case, please check the SW_12V connection. This is power supply connector for Audio power amplifier stage unlike the mcHF. | Im falle von fehlendem Audio out: just in case, please check the SW_12V connection. This is power supply connector for Audio power amplifier stage unlike the mcHF. |
