ovi40_uiboardtest [15.01.2018 10:43] – [Flashen des UI Boards] df9ts | ovi40test:uiboardtest [17.01.2018 18:04] – df9ts | ||
- | + | {{tag> | |
- | ==== Flashen des UI Boards ==== | + | |
- | - +8V on JP1 pin 29 - to power the USB stick! | + | |
- | - Press and hold! BAND - | + | |
- | - +5V on JP1 pin 28 - to envoke bootloader | + | |
- | - Put USB stick into USB port - with the appropriate name of FW (fw-40SDR.bin) | + | |
- | - Wait for it to finish FW upload | + | |
- | - Release the BAND - | + | |
- | - Power cycle +5V | + | |
==== UI Board Test & Fehlersuche ==== | ==== UI Board Test & Fehlersuche ==== |
