ovi40_uiboardtest [15.01.2018 10:43] – [Flashen des UI Boards] df9ts | ovi40test:uiboardtest [18.01.2018 23:59] – df9ts | ||
- | ==== Flashen des UI Boards ==== | + | ===== UI Board Test & Fehlersuche |
- | - +8V on JP1 pin 29 - to power the USB stick! | + | |
- | - Press and hold! BAND - | + | |
- | - +5V on JP1 pin 28 - to envoke bootloader | + | |
- | - Put USB stick into USB port - with the appropriate name of FW (fw-40SDR.bin) | + | |
- | - Wait for it to finish FW upload | + | |
- | - Release the BAND - | + | |
- | - Power cycle +5V | + | |
- | ==== UI Board Test & Fehlersuche ==== | + | |
Zeile 40: | Zeile 23: | ||
+ | ==== MCU wiederbeleben (" | ||
+ | If something strange or unexpected happened to your board and none of the usual procedure are working to install the Bootloader or the Firmware, this might bring life back into your UI. | ||
+ | You will need : | ||
+ | - an up to date STM32 ST-LINK utility ( http:// | ||
+ | - a ST-LINKV2 probe ( http:// | ||
+ | - latest version of the Bootloader and/or UHSDR Firmware | ||
+ | The only tricky part is to connect the probe JTAP connector to the JP8 UI board, here are the needed wires : | ||
+ | JP8-3 (SWDIO) to JTAG-7 | ||
+ | JP8-4 (SWCLK) to JTAG-9 | ||
+ | JP8-5 (UI_3V3) to JTAG-1 | ||
+ | JP8-6 (GND) to JTAG-20 | ||
+ | The rest of the procedure is straight forward : connect, erase, flash and you are done. | ||
+ | One additional trick, when I first connected to the MCU, I got an error message « Readout Protection Mode » and was unable to erase the chip. I finally choosed to try to flash a first time and the utility did what was necessary to remove the protection mode. Cool, thank you STM ! | ||
+ | A couple of us faced the same issue during beta testing the new UI board. | ||
+ | But as you could see a cheap chinese ST Link adapter from Amazon or eBay saves your day | ||
+ | Here are the steps. Unfortunately in German but maybe it helps. | ||
+ | Register values from Andreas: | ||
+ | The URLs are from a (forgotten) I40 UI thread in the mcHF folder. | ||
