ovi40_uiboardtest [15.01.2018 10:43] – [Flashen des UI Boards] df9ts | ovi40test:uiboardtest [07.02.2018 06:22] – df9ts_user | ||
- | ==== Flashen des UI Boards | + | ==== EEPROM IC7 Einbau Lage ==== |
- | === Bootloader laden === | + | This is where the dot is printed. Also the edge of the case is slanted near the 1-4 pins. See [[http://ww1.microchip.com/downloads/en/ |
- | Siehe auch [[https://www.amateurfunk-sulingen.de/mchf-projekt/inbetriebnahme-tipps#start|mcHF Inbetriebnahme Tipps]] | + | |
- | Stromversorgung dazu 5 Volt Pin 28+ , Pin 30 Gnd) | + | ==== Achtung: MCU Pin1 Markierung |
- | - +8V on JP1 pin 29 - to power the USB stick! | + | |
- | - Press and hold! BAND - | + | |
- | - +5V on JP1 pin 28 - to envoke bootloader | + | |
- | - Put USB stick into USB port - with the appropriate name of FW (fw-40SDR.bin) | + | |
- | - Wait for it to finish FW upload | + | |
- | - Release the BAND - | + | |
- | - Power cycle +5V | + | |
Zeile 40: | Zeile 29: | ||
+ | Prüfen: | ||
+ | Bitte +12V Versorgung des NF Audio Verstärkers messen. Er wird vom OVI40 RF Board über JP1 versorgt. | ||
+ | Bitte +8V Versorgung von RF Board prüfen, JP1. | ||
