ovi40test:uiboardtest [18.01.2018 23:59] – df9ts | ovi40test:uiboardtest [03.02.2018 16:40] – Forum Post Troubleshooting eingebaut df9ts_user | ||
{{tag> | {{tag> | ||
- | ===== UI Board Test & Fehlersuche ===== | + | ==== Achtung: MCU Pin1 Markierung |
Zeile 24: | Zeile 30: | ||
- | ==== MCU wiederbeleben ("bricked MCU") ==== | + | ==== "WM8731 not detected" ==== |
- | If something strange or unexpected happened to your board and none of the usual procedure are working to install the Bootloader or the Firmware, this might bring life back into your UI. | + | Bei UHSDR Fehlermeldung " |
- | You will need : | + | |
- | - an up to date STM32 ST-LINK utility ( http:// | + | |
- | - a ST-LINKV2 probe ( http:// | + | |
- | - latest version of the Bootloader and/ | + | |
- | The only tricky part is to connect the probe JTAP connector to the JP8 UI board, here are the needed wires : | + | |
- | JP8-3 (SWDIO) to JTAG-7 | + | |
- | JP8-4 (SWCLK) to JTAG-9 | + | |
- | JP8-5 (UI_3V3) to JTAG-1 | + | |
- | JP8-6 (GND) to JTAG-20 | + | |
- | The rest of the procedure is straight forward : connect, erase, flash and you are done. | + | |
- | One additional trick, when I first connected to the MCU, I got an error message « Readout Protection Mode » and was unable to erase the chip. I finally choosed to try to flash a first time and the utility did what was necessary to remove the protection mode. Cool, thank you STM ! | + | |
- | [{{: | + | ==== MCU läuft gar nicht, auch DFU Verbindung geht nicht ==== |
- | A couple of us faced the same issue during beta testing the new UI board. | + | Nach dem booten legt die MCU 3.3V an die Taster. Um erfolgreich zu booten braucht die MCU: |
- | But as you could see a cheap chinese ST Link adapter from Amazon or eBay saves your day | + | * CPU Takt (-> TXCO Takt messen) |
- | Here are the steps. Unfortunately in German but maybe it helps. | + | Falls dies der Fall ist, funktioniert Ansprechen über ST-Link Adapter und gesetzten Junper P6 im " |
- | https:// | + | |
- | Register values from Andreas: | + | |
- | The URLs are from a (forgotten) I40 UI thread in the mcHF folder. | + | Buttons, LEDs und LCD sind da noch nicht initialisiert. Erst wenn der Bootloader installiert wurde und läuft hat man minimalistisch |
