ovi40test:uiboardtest [19.01.2018 08:14] – df9ts_user | ovi40test:uiboardtest [22.01.2018 22:48] – df9ts | ||
{{tag> | {{tag> | ||
- | ===== UI Board Test & Fehlersuche ===== | + | ==== Achtung: MCU Pin1 Markierung |
Zeile 23: | Zeile 29: | ||
- | ==== MCU wiederbeleben (" | ||
- | Eine nicht mehr funktionierende OVI40 MCU kann - sofern es sich um keinen Hardware Defekt handelt - auf 3 Wegen wiederbelebt werden: | ||
- | - via USB-Stick (.bin-Datei) | ||
- | - via DFU und USB-Kabel (.dfu oder .bin - in letztem Fall musst Du die Startadresse mitgeben 0x810000) | ||
- | - via ST-Link (.bin-Datei - auch hier musst Du die Startadresse wie bei 2) angeben) | ||
- | Die Dateien dazu finden sich hier:. | ||
- | You will need : | ||
- | - an up to date STM32 ST-LINK utility ( http:// | ||
- | - a ST-LINKV2 probe ( http:// | ||
- | - latest version of the Bootloader and/or UHSDR Firmware | ||
- | The only tricky part is to connect the probe JTAP connector to the JP8 UI board, here are the needed wires : | ||
- | JP8-3 (SWDIO) to JTAG-7 | ||
- | JP8-4 (SWCLK) to JTAG-9 | ||
- | JP8-5 (UI_3V3) to JTAG-1 | ||
- | JP8-6 (GND) to JTAG-20 | ||
- | The rest of the procedure is straight forward : connect, erase, flash and you are done. | ||
- | One additional trick, when I first connected to the MCU, I got an error message « Readout Protection Mode » and was unable to erase the chip. I finally choosed to try to flash a first time and the utility did what was necessary to remove the protection mode. Cool, thank you STM ! | ||
- | A couple of us faced the same issue during beta testing the new UI board. | ||
- | But as you could see a cheap chinese ST Link adapter from Amazon or eBay saves your day | ||
- | Here are the steps. Unfortunately in German but maybe it helps. | ||
- | https:// | ||
- | Register values from Andreas: | ||
- | https:// | ||
- | The URLs are from a (forgotten) I40 UI thread in the mcHF folder. | ||
