ovi40wiki:wikitodo [21.01.2018 23:54] – df9ts_user | ovi40wiki:wikitodo [07.02.2018 22:01] – [Wiki Howto] df9ts | ||
+ | ===== Wiki Howto ===== | ||
Zeile 12: | Zeile 10: | ||
* https:// | * https:// | ||
* http:// | * http:// | ||
- | + | * Align German and English versions of [[: | |
+ | * Do multinamespace pages for toolchain etc., following WikiTodo example with plugin: | ||
+ | * Check tags used actually, compare with page overview for gaps | ||
+ | * Change page UI-Platine to use one namespace and include - remove germanenglish tag | ||
==== Stub Seiten - diese Seiten müssen noch erstellt werden ==== | ==== Stub Seiten - diese Seiten müssen noch erstellt werden ==== | ||
Zeile 23: | Zeile 25: | ||
{{topic> | {{topic> | ||
+ | ==== Seiten ok ==== | ||
+ | {{topic> | ||
