ovi40wiki:wikitodo [06.02.2018 10:07] – df9ts_user | ovi40wiki:wikitodo [07.02.2018 22:01] – [Wiki Howto] df9ts | ||
+ | ===== Wiki Howto ===== | ||
Zeile 12: | Zeile 10: | ||
* https:// | * https:// | ||
* http:// | * http:// | ||
- | * Toolchain change for new compiler see https://github.com/ | + | * Align German and English versions of [[:ovi40test: |
+ | * Do multinamespace pages for toolchain etc., following WikiTodo example with plugin: | ||
+ | * Check tags used actually, compare with page overview for gaps | ||
+ | * Change page UI-Platine to use one namespace and include - remove germanenglish tag | ||
==== Stub Seiten - diese Seiten müssen noch erstellt werden ==== | ==== Stub Seiten - diese Seiten müssen noch erstellt werden ==== |
