ovi40wiki:wikitodo [06.02.2018 10:31] – df9ts_user | ovi40wiki:wikitodo [08.02.2018 06:12] – df9ts | ||
+ | ===== Wiki Howto ===== | ||
Zeile 12: | Zeile 10: | ||
* https:// | * https:// | ||
* http:// | * http:// | ||
- | * Toolchain change for new compiler see https:// | + | * Align German and English versions of [[:ovi40test: |
- | * Do and test OpenOCD https:// | + | * Check tags used actually, compare with page overview for gaps |
==== Stub Seiten - diese Seiten müssen noch erstellt werden ==== | ==== Stub Seiten - diese Seiten müssen noch erstellt werden ==== | ||
Zeile 27: | Zeile 25: | ||
{{topic> | {{topic> | ||
+ | ====Include Seiten ==== | ||
+ | {{topic> | ||
+ | ==== Autogenerate Seiten ==== | ||
+ | {{topic> | ||
