ovi40wiki:wikitodo [07.02.2018 07:30] – df9ts_user | ovi40wiki:wikitodo [11.02.2018 15:49] – df9ts_user | ||
- | {{tag> | + | {{tag> |
- | ===== Wiki Howto ===== | + | |
+ | ===== Wiki ToDo ===== | ||
Zeile 14: | Zeile 11: | ||
* https:// | * https:// | ||
* http:// | * http:// | ||
- | * Do and test OpenOCD https:// | + | * Align German |
- | * One multilangage wiki todo page? (This collides with the language setting to change UI with language with content) | + | * Check tags used actually, compare with page overview for gaps |
==== Stub Seiten - diese Seiten müssen noch erstellt werden ==== | ==== Stub Seiten - diese Seiten müssen noch erstellt werden ==== | ||
Zeile 29: | Zeile 26: | ||
{{topic> | {{topic> | ||
+ | ====Include Seiten ==== | ||
+ | {{topic> | ||
+ | ==== Autogenerate Seiten ==== | ||
+ | {{topic> | ||
