ovi40wiki:wikitodo [07.02.2018 14:44] – [Wiki Howto] df9ts | ovi40wiki:wikitodo [08.02.2018 06:12] – df9ts | ||
Zeile 3: | Zeile 3: | ||
Zeile 14: | Zeile 10: | ||
* https:// | * https:// | ||
* http:// | * http:// | ||
- | * Do and test OpenOCD https:// | + | * Align German |
- | * One multilangage wiki todo page? (This collides with the language setting to change UI with language with content) | + | * Check tags used actually, compare with page overview for gaps |
- | * Translate ovi40what: | + | |
==== Stub Seiten - diese Seiten müssen noch erstellt werden ==== | ==== Stub Seiten - diese Seiten müssen noch erstellt werden ==== | ||
Zeile 30: | Zeile 25: | ||
{{topic> | {{topic> | ||
+ | ====Include Seiten ==== | ||
+ | {{topic> | ||
+ | ==== Autogenerate Seiten ==== | ||
+ | {{topic> | ||
