ovi40wiki:wikitodo [07.02.2018 16:00] – [Wiki Howto] df9ts | ovi40wiki:wikitodo [07.02.2018 21:43] – [Wiki Howto] df9ts | ||
Zeile 3: | Zeile 3: | ||
Zeile 14: | Zeile 10: | ||
* https:// | * https:// | ||
* http:// | * http:// | ||
- | * Do and test OpenOCD https:// | + | * Align German |
- | * One multilangage wiki todo page? (This collides with the language setting to change UI with language with content) | + | * Do multinamespace pages for toolchain etc., following WikiTodo example with plugin: |
- | * Translate ovi40what: | + | |
- | * Translate to English: | + | |
