ovi40wiki:wikitodo [07.02.2018 16:00] – [Wiki Howto] df9ts | ovi40wiki:wikitodo [11.02.2018 15:42] – df9ts_user | ||
- | {{tag> | + | {{tag> |
===== Wiki Howto ===== | ===== Wiki Howto ===== | ||
Zeile 14: | Zeile 11: | ||
* https:// | * https:// | ||
* http:// | * http:// | ||
- | * Do and test OpenOCD https:// | + | * Align German |
- | * One multilangage wiki todo page? (This collides with the language setting to change UI with language with content) | + | * Check tags used actually, compare with page overview for gaps |
- | * Translate ovi40what: | + | |
- | * Translate to English: | + | |
==== Stub Seiten - diese Seiten müssen noch erstellt werden ==== | ==== Stub Seiten - diese Seiten müssen noch erstellt werden ==== | ||
Zeile 32: | Zeile 26: | ||
{{topic> | {{topic> | ||
+ | ====Include Seiten ==== | ||
+ | {{topic> | ||
+ | ==== Autogenerate Seiten ==== | ||
+ | {{topic> | ||
