ovi40wiki:wikitodo [07.02.2018 21:42] – [Wiki Howto] df9ts | ovi40wiki:wikitodo [07.02.2018 22:01] – [Wiki Howto] df9ts | ||
Zeile 3: | Zeile 3: | ||
Zeile 14: | Zeile 10: | ||
* https:// | * https:// | ||
* http:// | * http:// | ||
- | * Do and test OpenOCD https:// | ||
- | * One multilangage wiki todo page? (This collides with the language setting to change UI with language with content) | ||
- | * Translate ovi40what: | ||
* Align German and English versions of [[: | * Align German and English versions of [[: | ||
* Do multinamespace pages for toolchain etc., following WikiTodo example with plugin: | * Do multinamespace pages for toolchain etc., following WikiTodo example with plugin: | ||
+ | * Check tags used actually, compare with page overview for gaps | ||
+ | * Change page UI-Platine to use one namespace and include - remove germanenglish tag | ||
