Beide Seiten der vorigen Revision Vorhergehende Überarbeitung | Nächste ÜberarbeitungBeide Seiten der Revision | ||
projekte:ovi40-sdr:bom [27.09.2017 18:00] – df8oe | projekte:ovi40-sdr:bom [27.09.2017 18:03] – df8oe | ||
Zeile 3: | Zeile 3: | ||
UI-Platine: | UI-Platine: | ||
- | |BOM OVI40-SDR UI V1.7||24-09-2017|DF8OE|||Distributor|||||| | + | |BOM OVI40-SDR UI V1.7| |24-09-2017|DF8OE| | |Distributor| | | | | | |
^Part^Value^Description^Package^Amount^FARNELL^Price^Reichelt^Price^Mouser^Price^Digikey^Price| | ^Part^Value^Description^Package^Amount^FARNELL^Price^Reichelt^Price^Mouser^Price^Digikey^Price| | ||
- | |IC1 / | + | |IC1 / |
- | |||or Audio CODEC TLV320AIC23BPWG4|SSOP28|2|120-7297|9, | + | | | |or Audio CODEC TLV320AIC23BPWG4|SSOP28|2|120-7297|9, |
- | |IC2|LM4952TS|TI Stereo Audio PA|LM4952|1|100-8028|3, | + | |IC2|LM4952TS|TI Stereo Audio PA|LM4952|1|100-8028|3, |
- | |IC3|LP5907_Q1|TI low noise LDO 3,3 Volt|SOT23-5|1|249-2304|0, | + | |IC3|LP5907_Q1|TI low noise LDO 3,3 Volt|SOT23-5|1|249-2304|0, |
- | |IC4|STM32F76X_ZIT6|MCU|LQFP144|1|253-5499|12, | + | |IC4|STM32F76X_ZIT6|MCU|LQFP144|1|253-5499|12, |
- | |IC5|ASTX-H11|16 MHz TCXO 2, | + | |IC5|ASTX-H11|16 MHz TCXO 2, |
- | |IC6|KA78RM33R|3, | + | |IC6|KA78RM33R|3, |
- | |IC7|AT24CM02|I2C | + | |IC7|AT24CM02|I2C |
- | |IC8|NCP5501DT50G|5, | + | |IC8|NCP5501DT50G|5, |
- | |Q1|32,768 kHz|QCM-315_SMD|CM315|1|||||695-CM315D-32.7KEZFT||300-8813-1-ND|0, | + | |Q1|32,768 kHz|QCM-315_SMD|CM315|1| | | | |695-CM315D-32.7KEZFT| |300-8813-1-ND|0, |
- | |T3|BC857|PNP Transistor|SOT23|1|179-8067|0, | + | |T3|BC857|PNP Transistor|SOT23|1|179-8067|0, |
- | |D5|BAV70|Double Diode|SOT23|2|267-7467|0, | + | |D5|BAV70|Double Diode|SOT23|2|267-7467|0, |
- | |D6|BAV70|Double Diode|SOT23|.||||||||| | + | |D6|BAV70|Double Diode|SOT23|.| | | | | | | | | |
- | |D7|BAS85|Schottky barrier diode |SOD80C|3|146-9394|0, | + | |D7|BAS85|Schottky barrier diode |SOD80C|3|146-9394|0, |
- | |D8|BAS85|Schottky barrier diode|SOD80C|.||||||||| | + | |D8|BAS85|Schottky barrier diode|SOD80C|.| | | | | | | | | |
- | |D9|BAS85|Schottky barrier diode|SOD80C|.||||||||| | + | |D9|BAS85|Schottky barrier diode|SOD80C|.| | | | | | | | | |
- | |D1|green|LED|LED_3MM|1|276-4976|0, | + | |D1|green|LED|LED_3MM|1|276-4976|0, |
- | |D2|red|LED|LED_3MM|1|276-4977|0, | + | |D2|red|LED|LED_3MM|1|276-4977|0, |
- | |D3|blue|LED|LED_3MM|1|276-4975|0, | + | |D3|blue|LED|LED_3MM|1|276-4975|0, |
- | |BAT1-HOLDER||Battery Holder CR2032||1|188-5903|2, | + | |BAT1-HOLDER| |Battery Holder CR2032| |1|188-5903|2, |
- | |BAT1|CR2032P_L|Lithium | + | |BAT1|CR2032P_L|Lithium |
- | |X1|PN87520-S|USB Plug HOST|PN87520-S|1|117-7883|0, | + | |X1|PN87520-S|USB Plug HOST|PN87520-S|1|117-7883|0, |
- | |J11|MINI-USB_B|USB Plug DFU|MINI-USB_B|1|211-2367|0, | + | |J11|MINI-USB_B|USB Plug DFU|MINI-USB_B|1|211-2367|0, |
- | |LCD1|HY32D|3, | + | |LCD1|HY32D|3, |
- | |L1|47uH|L_SMD1005|L1005|3|221-5655|0, | + | |L1|47uH|L_SMD1005|L1005|3|221-5655|0, |
- | |L2|47uH|L_SMD1005|L1005|.||||||||| | + | |L2|47uH|L_SMD1005|L1005|.| | | | | | | | | |
- | |L3|47uH|L_SMD1005|L1005|.||||||||| | + | |L3|47uH|L_SMD1005|L1005|.| | | | | | | | | |
- | |R1|47k|SMD Resistor TK50|0805|6|||SMD-0805 47k|0, | + | |R1|47k|SMD Resistor TK50|0805|6| | |SMD-0805 47k|0,02| | | | | |
- | |R1A|100R|SMD Resistor TK50|0603|13|||SMD-0603 100|0, | + | |R1A|100R|SMD Resistor TK50|0603|13| | |SMD-0603 100|0,03| | | | | |
- | |R1B|0R|SMD Resistor TK50|0603|3|||SMD-0603 0|0, | + | |R1B|0R|SMD Resistor TK50|0603|3| | |SMD-0603 0|0,03| | | | | |
- | |R2|1k|SMD Resistor TK50|0603|7|||SMD-0603 1, | + | |R2|1k|SMD Resistor TK50|0603|7| | |SMD-0603 1,0k|0,03| | | | | |
- | |R3|100R|SMD Resistor TK50|0603|.||||||||| | + | |R3|100R|SMD Resistor TK50|0603|.| | | | | | | | | |
- | |R4|1k|SMD Resistor TK50|0603|.||||||||| | + | |R4|1k|SMD Resistor TK50|0603|.| | | | | | | | | |
- | |R4B1|2R2|SMD Resistor TK50|1206|4|||SMD ¼W 2, | + | |R4B1|2R2|SMD Resistor TK50|1206|4| | |SMD ¼W 2,2|0,03| | | | | |
- | |R4D|2R2|SMD Resistor TK50|1206|.||||||||| | + | |R4D|2R2|SMD Resistor TK50|1206|.| | | | | | | | | |
- | |R5|0R|SMD Resistor TK50|0603|.||||||||| | + | |R5|0R|SMD Resistor TK50|0603|.| | | | | | | | | |
- | |R6|1k|SMD Resistor TK50|0603|.||||||||| | + | |R6|1k|SMD Resistor TK50|0603|.| | | | | | | | | |
- | |R7|1k|SMD Resistor TK50|0603|.||||||||| | + | |R7|1k|SMD Resistor TK50|0603|.| | | | | | | | | |
- | |R8|100R|SMD Resistor TK50|0603|.||||||||| | + | |R8|100R|SMD Resistor TK50|0603|.| | | | | | | | | |
- | |R9|4k7|SMD Resistor TK50|0805|4|||SMD-0805 4, | + | |R9|4k7|SMD Resistor TK50|0805|4| | |SMD-0805 4,7k|0,02| | | | | |
- | |R10|4k7|SMD Resistor TK50|0603|1|||SMD-0603 4, | + | |R10|4k7|SMD Resistor TK50|0603|1| | |SMD-0603 4,7k|0,02| | | | | |
- | |R11|4k7|SMD Resistor TK50|0805|.||||||||| | + | |R11|4k7|SMD Resistor TK50|0805|.| | | | | | | | | |
- | |R12|4k7|SMD Resistor TK50|0805|.||||||||| | + | |R12|4k7|SMD Resistor TK50|0805|.| | | | | | | | | |
- | |R13|47R|SMD Resistor TK50|0603|7|||SMD-0603 47|0, | + | |R13|47R|SMD Resistor TK50|0603|7| | |SMD-0603 47|0,03| | | | | |
- | |R14|47R|SMD Resistor TK50|0603|.||||||||| | + | |R14|47R|SMD Resistor TK50|0603|.| | | | | | | | | |
- | |R15|1k|SMD Resistor TK50|0603|.||||||||| | + | |R15|1k|SMD Resistor TK50|0603|.| | | | | | | | | |
- | |R16|100R|SMD Resistor TK50|0603|.||||||||| | + | |R16|100R|SMD Resistor TK50|0603|.| | | | | | | | | |
- | |R17|100R|SMD Resistor TK50|0603|.||||||||| | + | |R17|100R|SMD Resistor TK50|0603|.| | | | | | | | | |
- | |R18|100R|SMD Resistor TK50|0603|.||||||||| | + | |R18|100R|SMD Resistor TK50|0603|.| | | | | | | | | |
- | |R19|100R|SMD Resistor TK50|0603|.||||||||| | + | |R19|100R|SMD Resistor TK50|0603|.| | | | | | | | | |
- | |R20|100R|SMD Resistor TK50|0603|.||||||||| | + | |R20|100R|SMD Resistor TK50|0603|.| | | | | | | | | |
- | |R21|47R|SMD Resistor TK50|0603|.||||||||| | + | |R21|47R|SMD Resistor TK50|0603|.| | | | | | | | | |
- | |R22|47R|SMD Resistor TK50|0603|.||||||||| | + | |R22|47R|SMD Resistor TK50|0603|.| | | | | | | | | |
- | |R23|0R|SMD Resistor TK50|0805|8|||SMD-0805 0|0, | + | |R23|0R|SMD Resistor TK50|0805|8| | |SMD-0805 0|0,02| | | | | |
- | |R24|680R|SMD Resistor TK50|0805|4|||SMD-0805 680|0, | + | |R24|680R|SMD Resistor TK50|0805|4| | |SMD-0805 680|0,02| | | | | |
- | |R25|4k7|SMD Resistor TK50|0805|.||||||||| | + | |R25|4k7|SMD Resistor TK50|0805|.| | | | | | | | | |
- | |R26|100R|SMD Resistor TK50|0603|.||||||||| | + | |R26|100R|SMD Resistor TK50|0603|.| | | | | | | | | |
- | |R27|100R|SMD Resistor TK50|0603|.||||||||| | + | |R27|100R|SMD Resistor TK50|0603|.| | | | | | | | | |
- | |R28|100R|SMD Resistor TK50|0603|.||||||||| | + | |R28|100R|SMD Resistor TK50|0603|.| | | | | | | | | |
- | |R29|1k|SMD Resistor TK50|0603|.||||||||| | + | |R29|1k|SMD Resistor TK50|0603|.| | | | | | | | | |
- | |R30|0R|SMD Resistor TK50|0805|.||||||||| | + | |R30|0R|SMD Resistor TK50|0805|.| | | | | | | | | |
- | |R31|0R|SMD Resistor TK50|0805|.||||||||| | + | |R31|0R|SMD Resistor TK50|0805|.| | | | | | | | | |
- | |R32|0R|SMD Resistor TK50|0805|.||||||||| | + | |R32|0R|SMD Resistor TK50|0805|.| | | | | | | | | |
- | |R33|100R|SMD Resistor TK50|0603|.||||||||| | + | |R33|100R|SMD Resistor TK50|0603|.| | | | | | | | | |
- | |R34|100R|SMD Resistor TK50|0603|.||||||||| | + | |R34|100R|SMD Resistor TK50|0603|.| | | | | | | | | |
- | |R35A|4R7|SMD Resistor TK50|1206|1|||SMD ¼W 4, | + | |R35A|4R7|SMD Resistor TK50|1206|1| | |SMD ¼W 4,7|0,03| | | | | |
- | |R36|680R|SMD Resistor TK50|0805|.||||||||| | + | |R36|680R|SMD Resistor TK50|0805|.| | | | | | | | | |
- | |R37|680R|SMD Resistor TK50|0805|.||||||||| | + | |R37|680R|SMD Resistor TK50|0805|.| | | | | | | | | |
- | |R40|1k|SMD Resistor TK50|0603|.||||||||| | + | |R40|1k|SMD Resistor TK50|0603|.| | | | | | | | | |
- | |R41|47R|SMD Resistor TK50|0603|.||||||||| | + | |R41|47R|SMD Resistor TK50|0603|.| | | | | | | | | |
- | |R45|2R2|SMD Resistor TK50|1206|.||||||||| | + | |R45|2R2|SMD Resistor TK50|1206|.| | | | | | | | | |
- | |R46|2R2|SMD Resistor TK50|1206|.||||||||| | + | |R46|2R2|SMD Resistor TK50|1206|.| | | | | | | | | |
- | |R47|47R|SMD Resistor TK50|0603|.||||||||| | + | |R47|47R|SMD Resistor TK50|0603|.| | | | | | | | | |
- | |R48|47R|SMD Resistor TK50|0603|.||||||||| | + | |R48|47R|SMD Resistor TK50|0603|.| | | | | | | | | |
- | |R101|0R|SMD Resistor TK50|0603|.||||||||| | + | |R101|0R|SMD Resistor TK50|0603|.| | | | | | | | | |
- | |R108|0R|SMD Resistor TK50|0805|.||||||||| | + | |R108|0R|SMD Resistor TK50|0805|.| | | | | | | | | |
- | |R110|0R|SMD Resistor TK50|0805|.||||||||| | + | |R110|0R|SMD Resistor TK50|0805|.| | | | | | | | | |
- | |R112|0R|SMD Resistor TK50|0805|.||||||||| | + | |R112|0R|SMD Resistor TK50|0805|.| | | | | | | | | |
- | |R114|0R|SMD Resistor TK50|0805|.||||||||| | + | |R114|0R|SMD Resistor TK50|0805|.| | | | | | | | | |
- | |R116|680R|SMD Resistor TK50|0805|.||||||||| | + | |R116|680R|SMD Resistor TK50|0805|.| | | | | | | | | |
- | |R120|47k|SMD Resistor TK50|0805|.||||||||| | + | |R120|47k|SMD Resistor TK50|0805|.| | | | | | | | | |
- | |R121|47k|SMD Resistor TK50|0805|.||||||||| | + | |R121|47k|SMD Resistor TK50|0805|.| | | | | | | | | |
- | |R122|47k|SMD Resistor TK50|0805|.||||||||| | + | |R122|47k|SMD Resistor TK50|0805|.| | | | | | | | | |
- | |R123|47k|SMD Resistor TK50|0805|.||||||||| | + | |R123|47k|SMD Resistor TK50|0805|.| | | | | | | | | |
- | |R124|47k|SMD Resistor TK50|0805|.||||||||| | + | |R124|47k|SMD Resistor TK50|0805|.| | | | | | | | | |
- | |C1|1nF|SMD Chip Capacitor NP0/ | + | |C1|1nF|SMD Chip Capacitor NP0/ |
- | |C1A|1nF|SMD Chip Capacitor NP0/ | + | |C1A|1nF|SMD Chip Capacitor NP0/ |
- | |C1B|1nF|SMD Chip Capacitor NP0/ | + | |C1B|1nF|SMD Chip Capacitor NP0/ |
- | |C1C|1nF|SMD Chip Capacitor NP0/ | + | |C1C|1nF|SMD Chip Capacitor NP0/ |
- | |C1D|1nF|SMD Chip Capacitor NP0/ | + | |C1D|1nF|SMD Chip Capacitor NP0/ |
- | |C2|1nF|SMD Chip Capacitor NP0/ | + | |C2|1nF|SMD Chip Capacitor NP0/ |
- | |C3|1nF|SMD Chip Capacitor NP0/ | + | |C3|1nF|SMD Chip Capacitor NP0/ |
- | |C4|1nF|SMD Chip Capacitor NP0/ | + | |C4|1nF|SMD Chip Capacitor NP0/ |
- | |C5|220uF|SMD Tantal-ELKO 10V|TA-C|5|||TAJ 6032 220/ | + | |C5|220uF|SMD Tantal-ELKO 10V|TA-C|5| | |TAJ 6032 220/ |
- | |C6|220uF|SMD Tantal-ELKO 10V|TA-C|.||||||||| | + | |C6|220uF|SMD Tantal-ELKO 10V|TA-C|.| | | | | | | | | |
- | |C7|470nF|SMD Chip Capacitor NP0/ | + | |C7|470nF|SMD Chip Capacitor NP0/ |
- | |C8|470nF|SMD Chip Capacitor NP0/ | + | |C8|470nF|SMD Chip Capacitor NP0/ |
- | |C9|220uF|SMD Alu-Elko 16V low ESR|E_SMD_0608|6|||VF 220/16 P-D8|0, | + | |C9|220uF|SMD Alu-Elko 16V low ESR|E_SMD_0608|6| | |VF 220/16 P-D8|0,3| | | | | |
- | |C10|100nF|SMD Chip Capacitor X7R|0603|63|||X7R 0603FCF 100N|0, | + | |C10|100nF|SMD Chip Capacitor X7R|0603|63| | |X7R 0603FCF 100N|0,04| | | | | |
- | |C11|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C11|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C12|10uF|SMD Tantal-ELKO 16V|TA-B | + | |C12|10uF|SMD Tantal-ELKO 16V|TA-B |
- | |C13|10uF|SMD Tantal-ELKO 16V|TA-B | + | |C13|10uF|SMD Tantal-ELKO 16V|TA-B |
- | |C14|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C14|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C15|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C15|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C16|10uF|SMD Tantal-ELKO 16V|TA-B | + | |C16|10uF|SMD Tantal-ELKO 16V|TA-B |
- | |C17|10uF|SMD Tantal-ELKO 16V|TA-B | + | |C17|10uF|SMD Tantal-ELKO 16V|TA-B |
- | |C18|1uF|SMD Chip Capacitor NP0/ | + | |C18|1uF|SMD Chip Capacitor NP0/ |
- | |C19|1uF|SMD Chip Capacitor NP0/ | + | |C19|1uF|SMD Chip Capacitor NP0/ |
- | |C20|470nF|SMD Chip Capacitor NP0/ | + | |C20|470nF|SMD Chip Capacitor NP0/ |
- | |C21|1nF|SMD Chip Capacitor NP0/ | + | |C21|1nF|SMD Chip Capacitor NP0/ |
- | |C22|10uF|SMD Tantal-ELKO 16V|TA-B | + | |C22|10uF|SMD Tantal-ELKO 16V|TA-B |
- | |C23|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C23|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C24|4.7uF|SMD Tantal-ELKO |TA-A 3,2 x 1, | + | |C24|4.7uF|SMD Tantal-ELKO |TA-A 3,2 x 1,6|1| | |T491A 4,7U 16|0,04| | | | | |
- | |C25|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C25|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C26|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C26|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C27|220pF|SMD Chip Capacitor NP0/ | + | |C27|220pF|SMD Chip Capacitor NP0/ |
- | |C28|220pF|SMD Chip Capacitor NP0/ | + | |C28|220pF|SMD Chip Capacitor NP0/ |
- | |C29|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C29|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C30|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C30|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C31|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C31|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C32|220uF|SMD Alu-Elko 16V low ESR|E_SMD_0608|.||||||||| | + | |C32|220uF|SMD Alu-Elko 16V low ESR|E_SMD_0608|.| | | | | | | | | |
- | |C32B|220uF|SMD Alu-Elko 16V low ESR|E_SMD_0608|.||||||||| | + | |C32B|220uF|SMD Alu-Elko 16V low ESR|E_SMD_0608|.| | | | | | | | | |
- | |C33|220uF|SMD Alu-Elko 16V low ESR|E_SMD_0608|.||||||||| | + | |C33|220uF|SMD Alu-Elko 16V low ESR|E_SMD_0608|.| | | | | | | | | |
- | |C34|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C34|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C35|220uF|SMD Alu-Elko 16V low ESR|E_SMD_0608|.||||||||| | + | |C35|220uF|SMD Alu-Elko 16V low ESR|E_SMD_0608|.| | | | | | | | | |
- | |C36|1nF|SMD Chip Capacitor NP0/ | + | |C36|1nF|SMD Chip Capacitor NP0/ |
- | |C37|1nF|SMD Chip Capacitor NP0/ | + | |C37|1nF|SMD Chip Capacitor NP0/ |
- | |C38|1nF|SMD Chip Capacitor NP0/ | + | |C38|1nF|SMD Chip Capacitor NP0/ |
- | |C39|220uF|SMD Tantal-ELKO 10V|TA-C|.||||||||| | + | |C39|220uF|SMD Tantal-ELKO 10V|TA-C|.| | | | | | | | | |
- | |C40|470nF|SMD Chip Capacitor NP0/ | + | |C40|470nF|SMD Chip Capacitor NP0/ |
- | |C41|10uF|SMD Tantal-ELKO 16V|TA-B | + | |C41|10uF|SMD Tantal-ELKO 16V|TA-B |
- | |C42|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C42|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C43|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C43|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C44|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C44|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C45|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C45|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C46|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C46|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C47|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C47|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C48|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C48|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C49|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C49|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C50|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C50|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C51|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C51|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C52|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C52|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C53|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C53|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C54|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C54|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C55|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C55|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C56|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C56|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C57|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C57|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C58|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C58|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C59|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C59|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C60|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C60|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C61|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C61|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C62|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C62|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C63|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C63|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C64|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C64|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C65|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C65|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C66|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C66|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C67|1nF|SMD Chip Capacitor NP0/ | + | |C67|1nF|SMD Chip Capacitor NP0/ |
- | |C68|1nF|SMD Chip Capacitor NP0/ | + | |C68|1nF|SMD Chip Capacitor NP0/ |
- | |C69|1nF|SMD Chip Capacitor NP0/ | + | |C69|1nF|SMD Chip Capacitor NP0/ |
- | |C70|1nF|SMD Chip Capacitor NP0/ | + | |C70|1nF|SMD Chip Capacitor NP0/ |
- | |C71|1nF|SMD Chip Capacitor NP0/ | + | |C71|1nF|SMD Chip Capacitor NP0/ |
- | |C72|1nF|SMD Chip Capacitor NP0/ | + | |C72|1nF|SMD Chip Capacitor NP0/ |
- | |C73|1nF|SMD Chip Capacitor NP0/ | + | |C73|1nF|SMD Chip Capacitor NP0/ |
- | |C74|1nF|SMD Chip Capacitor NP0/ | + | |C74|1nF|SMD Chip Capacitor NP0/ |
- | |C74A|220uF|SMD Tantal-ELKO 10V|TA-C|.||||||||| | + | |C74A|220uF|SMD Tantal-ELKO 10V|TA-C|.| | | | | | | | | |
- | |C75|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C75|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C76|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C76|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C77|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C77|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C78|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C78|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C79|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C79|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C80|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C80|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C81|1uF |SMD Chip Capacitor NP0/ | + | |C81|1uF |SMD Chip Capacitor NP0/ |
- | |C82|1uF|SMD Chip Capacitor NP0/ | + | |C82|1uF|SMD Chip Capacitor NP0/ |
- | |C83|1uF |SMD Chip Capacitor NP0/ | + | |C83|1uF |SMD Chip Capacitor NP0/ |
- | |C84|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C84|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C85|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C85|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C86|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C86|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C87|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C87|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C88|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C88|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C89|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C89|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C90|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C90|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C91|2, | + | |C91|2, |
- | |C92|2, | + | |C92|2, |
- | |C93|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C93|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C94|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C94|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C95|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C95|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C96|220uF|SMD Alu-Elko 16V low ESR|E_SMD_0608|.||||||||| | + | |C96|220uF|SMD Alu-Elko 16V low ESR|E_SMD_0608|.| | | | | | | | | |
- | |C97|10uF|SMD Tantal-ELKO 16V|TA-B | + | |C97|10uF|SMD Tantal-ELKO 16V|TA-B |
- | |C98|10uF|SMD Tantal-ELKO 16V|TA-B | + | |C98|10uF|SMD Tantal-ELKO 16V|TA-B |
- | |C99|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C99|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C101|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C101|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C102|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C102|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C104|1uF|SMD Chip Capacitor NP0/ | + | |C104|1uF|SMD Chip Capacitor NP0/ |
- | |C105|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C105|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C106|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C106|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C107|1uF |SMD Chip Capacitor NP0/ | + | |C107|1uF |SMD Chip Capacitor NP0/ |
- | |C108|1uF|SMD Chip Capacitor NP0/ | + | |C108|1uF|SMD Chip Capacitor NP0/ |
- | |C109|220pF|SMD Chip Capacitor NP0/ | + | |C109|220pF|SMD Chip Capacitor NP0/ |
- | |C111|10uF|SMD Tantal-ELKO 16V|TA-B | + | |C111|10uF|SMD Tantal-ELKO 16V|TA-B |
- | |C112|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C112|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C120|220uF|SMD Tantal-ELKO 10V|TA-C|.||||||||| | + | |C120|220uF|SMD Tantal-ELKO 10V|TA-C|.| | | | | | | | | |
- | |C121|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C121|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C122|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C122|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C123|100nF|SMD Chip Capacitor X7R|0603|.||||||||| | + | |C123|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |
- | |C124|8,2pF – 10pF|SMD Chip Capacitor|0603|2|||NPO-G0603 10P |0, | + | |C124|8,2pF – 10pF|SMD Chip Capacitor|0603|2| | |NPO-G0603 10P |0,04| | | | | |
- | |C125|8,2pF – 10pF|SMD Chip Capacitor|0603|.||||||||| | + | |C125|8,2pF – 10pF|SMD Chip Capacitor|0603|.| | | | | | | | | |
- | |S1|G3|SMD Pushbutton KSC941J||18|243-5157|0, | + | |S1|G3|SMD Pushbutton KSC941J| |18|243-5157|0, |
- | |S2|G2|SMD Pushbutton KSC941J||.||||||||| | + | |S2|G2|SMD Pushbutton KSC941J| |.| | | | | | | | | |
- | |S3|M2|SMD Pushbutton KSC941J||.||||||||| | + | |S3|M2|SMD Pushbutton KSC941J| |.| | | | | | | | | |
- | |S4|BM|SMD Pushbutton KSC941J||.||||||||| | + | |S4|BM|SMD Pushbutton KSC941J| |.| | | | | | | | | |
- | |S5|G4|SMD Pushbutton KSC941J||.||||||||| | + | |S5|G4|SMD Pushbutton KSC941J| |.| | | | | | | | | |
- | |S6|M3|SMD Pushbutton KSC941J||.||||||||| | + | |S6|M3|SMD Pushbutton KSC941J| |.| | | | | | | | | |
- | |S7|SM|SMD Pushbutton KSC941J||.||||||||| | + | |S7|SM|SMD Pushbutton KSC941J| |.| | | | | | | | | |
- | |S8|SP|SMD Pushbutton KSC941J||.||||||||| | + | |S8|SP|SMD Pushbutton KSC941J| |.| | | | | | | | | |
- | |S9|M1|SMD Pushbutton KSC941J||.||||||||| | + | |S9|M1|SMD Pushbutton KSC941J| |.| | | | | | | | | |
- | |S10|F3|SMD Pushbutton KSC941J||.||||||||| | + | |S10|F3|SMD Pushbutton KSC941J| |.| | | | | | | | | |
- | |S11|F1|SMD Pushbutton KSC941J||.||||||||| | + | |S11|F1|SMD Pushbutton KSC941J| |.| | | | | | | | | |
- | |S12|F2|SMD Pushbutton KSC941J||.||||||||| | + | |S12|F2|SMD Pushbutton KSC941J| |.| | | | | | | | | |
- | |S13|F4|SMD Pushbutton KSC941J||.||||||||| | + | |S13|F4|SMD Pushbutton KSC941J| |.| | | | | | | | | |
- | |S14|BP|SMD Pushbutton KSC941J||.||||||||| | + | |S14|BP|SMD Pushbutton KSC941J| |.| | | | | | | | | |
- | |S15|F5|SMD Pushbutton KSC941J||.||||||||| | + | |S15|F5|SMD Pushbutton KSC941J| |.| | | | | | | | | |
- | |S16|G1|SMD Pushbutton KSC941J||.||||||||| | + | |S16|G1|SMD Pushbutton KSC941J| |.| | | | | | | | | |
- | |S17|Power|SMD Pushbutton KSC941J||.||||||||| | + | |S17|Power|SMD Pushbutton KSC941J| |.| | | | | | | | | |
- | |S18|not assigned yet|SMD Pushbutton KSC941J||.||||||||| | + | |S18|not assigned yet|SMD Pushbutton KSC941J| |.| | | | | | | | | |
- | |J1|1503_07|Audio Plug 3, | + | |J1|1503_07|Audio Plug 3, |
- | |J2|1503_07|Audio Plug 3, | + | |J2|1503_07|Audio Plug 3, |
- | |J3|1503_07|Audio Plug 3, | + | |J3|1503_07|Audio Plug 3, |
- | |J4|1503_09|Audio Plug w. 2 switches|1503_09|1|124-3244|2, | + | |J4|1503_09|Audio Plug w. 2 switches|1503_09|1|124-3244|2, |
- | |E1|EC12E_SW|Alps Encoder with push function|ALPS_EC12E_SW|4|152-0813|1, | + | |E1|EC12E_SW|Alps Encoder with push function|ALPS_EC12E_SW|4|152-0813|1, |
- | |E2|EC12E_SW|Alps Encoder with push function|ALPS_EC12E_SW|.||||||||| | + | |E2|EC12E_SW|Alps Encoder with push function|ALPS_EC12E_SW|.| | | | | | | | | |
- | |E3|EC12E_SW|Alps Encoder with push function|ALPS_EC12E_SW|.||||||||| | + | |E3|EC12E_SW|Alps Encoder with push function|ALPS_EC12E_SW|.| | | | | | | | | |
- | |E4|EC12E_SW|Alps Encoder with push function|ALPS_EC12E_SW|.||||||||| | + | |E4|EC12E_SW|Alps Encoder with push function|ALPS_EC12E_SW|.| | | | | | | | | |
- | ||Button Cap|Cap grey|BTNKSC920|4|||||||CKN10429-ND|0, | + | | |Button Cap|Cap grey|BTNKSC920|4| | | | | | |CKN10429-ND|0, |
- | ||Button Cap|Cap red|BTNKSC940|2|||||||CKN10428-ND|0, | + | | |Button Cap|Cap red|BTNKSC940|2| | | | | | |CKN10428-ND|0, |
- | ||Button Cap|Cap black|BTNKSC990|2|||||||CKN10426-ND|0, | + | | |Button Cap|Cap black|BTNKSC990|2| | | | | | |CKN10426-ND|0, |
- | ||Button Cap|Cap white|BTNKSC980|10|||||||CKN10427-ND|0, | + | | |Button Cap|Cap white|BTNKSC980|10| | | | | | |CKN10427-ND|0, |
- | |JP1|30 Pin Board to Board|Pinheader-1X30|1X30|1|||3x | + | |JP1|30 Pin Board to Board|Pinheader-1X30|1X30|1| | |3x 40-polig| | | | | | |
- | |JP2|25 Pin Board to Board|Pinheader-1X25|1X25|1||||||||| | + | |JP2|25 Pin Board to Board|Pinheader-1X25|1X25|1| | | | | | | | | |
- | |JP3| 6 Pin Board to Board|Pinheader-1X06|1X06|4||||||||| | + | |JP3| 6 Pin Board to Board|Pinheader-1X06|1X06|4| | | | | | | | | |
- | |P1|SW_12V|Pinheader-1X02|1X02|6||||||||| | + | |P1|SW_12V|Pinheader-1X02|1X02|6| | | | | | | | | |
- | |P2|Speaker left|Pinheader-1X02|1X02|.||||||||| | + | |P2|Speaker left|Pinheader-1X02|1X02|.| | | | | | | | | |
- | |P7|Speaker right|Pinheader-1X02|1X02|.||||||||| | + | |P7|Speaker right|Pinheader-1X02|1X02|.| | | | | | | | | |
- | |P6|DFU mode Jumper|Pinheader-1X02|1X02|.||||||||| | + | |P6|DFU mode Jumper|Pinheader-1X02|1X02|.| | | | | | | | | |
- | |JP8|DEBUG|Pinheader-1X06|1X06|.||||||||| | + | |JP8|DEBUG|Pinheader-1X06|1X06|.| | | | | | | | | |
- | |JP17|short S17|Pinheader-1X02|1X02|.||||||||| | + | |JP17|short S17|Pinheader-1X02|1X02|.| | | | | | | | | |
- | |JP5|ext. USB Host|Pinheader-1X04|1X04|2||||||||| | + | |JP5|ext. USB Host|Pinheader-1X04|1X04|2| | | | | | | | | |
- | |JP6|ext. USB DFU|Pinheader-1X04|1X04|.||||||||| | + | |JP6|ext. USB DFU|Pinheader-1X04|1X04|.| | | | | | | | | |
- | |JP4|ext. Audio|Pinheader-1X06|1X06|.||||||||| | + | |JP4|ext. Audio|Pinheader-1X06|1X06|.| | | | | | | | | |
- | |JP7|ext. Audio|Pinheader-1X06|1X06|.||||||||| | + | |JP7|ext. Audio|Pinheader-1X06|1X06|.| | | | | | | | | |
- | |P3|alternative Bridge Vbat|Pinheader-1X02|1X02|.||||||||| | + | |P3|alternative Bridge Vbat|Pinheader-1X02|1X02|.| | | | | | | | | |
- | |LCD1||Pinheader-2x17|2x17|1||||||||| | + | |LCD1| |Pinheader-2x17|2x17|1| | | | | | | | | |
- | |LCD/ | + | |LCD/PCB| |Holeheader low profile 2x17|BL 2X17G 2,54|1| | | | | | | | | |
- | |BU2|MOLEX_SD_49225-0821|MICROSD_Cardreader|Molex 503182-1853|1|176-4375|1, | + | |BU2|MOLEX_SD_49225-0821|MICROSD_Cardreader|Molex 503182-1853|1|176-4375|1, |
- | ||optional parts|||||||||||| | + | | |optional parts| | | | | | | | | | | | |
- | |D4|SS16SMA|Vishay General Semiconductor SS16|DIODE_SMA|||||||||| | + | |D4|SS16SMA|Vishay General Semiconductor SS16|DIODE_SMA| | | | | | | | | | |
- | |IC9|CY15B104Q|SPI FRAM|SO08|||||||||| | + | |IC9|CY15B104Q|SPI FRAM|SO08| | | | | | | | | | |
- | |IC11|SST25VF04B|SPI FLASH 2,7V, 4Mbit|SO08||||SST 25VF040B|0, | + | |IC11|SST25VF04B|SPI FLASH 2,7V, 4Mbit|SO08| | | |SST 25VF040B|0, |
