projekte:ovi40-sdr:bom [14.10.2017 16:53] – Fehlerkorrektur 0R 0603->0805 x 1 df8oe | projekte:ovi40-sdr:bom [03.01.2018 11:30] – [UI-Platine:] df8oe | ||
Zeile 3: | Zeile 3: | ||
====== UI-Platine: ====== | ====== UI-Platine: ====== | ||
- | **Achtung! Diese Liste ist vorläufig! Während des Betatests werden sich mit Sicherheit noch Änderungen ergeben.** | + | |BOM OVI40-SDR UI V1.7||24-09-2017|DF8OE| ||Distributor / Prices|||||| | |
- | z.B. ist der SD-Cardreader, | + | |
- | |BOM OVI40-SDR UI V1.7||24-09-2017|DF8OE| ||Distributor / Prices|||||| | + | |
^Part^Value^Description^Package^Amount^FARNELL^Price^Reichelt^Price^Mouser^Price^Digikey^Price| | ^Part^Value^Description^Package^Amount^FARNELL^Price^Reichelt^Price^Mouser^Price^Digikey^Price| | ||
|IC1 / | |IC1 / | ||
Zeile 14: | Zeile 10: | ||
|IC3|LP5907_Q1|TI low noise LDO 3,3 Volt|SOT23-5|1|249-2304|0, | |IC3|LP5907_Q1|TI low noise LDO 3,3 Volt|SOT23-5|1|249-2304|0, | ||
|IC4|STM32F76X_ZIT6|MCU|LQFP144|1|253-5499|12, | |IC4|STM32F76X_ZIT6|MCU|LQFP144|1|253-5499|12, | ||
- | |IC5|ASTX-H11|16 MHz TCXO 2, | + | |IC5|ASTX-H11|16 MHz TCXO 2,5ppm 3,2 x 2,5 mm|TCXO_32X25|1| | | | |815-ASTXH1116T| |535-12044-1-ND|2, |
|IC6|KA78RM33R|3, | |IC6|KA78RM33R|3, | ||
- | |IC7|AT24CM02|I2C | + | |IC7|AT24CM02|I2C EEPROM|SO08|1| | |24LC1026_ISN| |579-24LC1026I/ |
|IC8|NCP5501DT50G|5, | |IC8|NCP5501DT50G|5, | ||
|Q1|32,768 kHz|QCM-315_SMD|CM315|1| | | | |695-CM315D-32.7KEZFT| |300-8813-1-ND|0, | |Q1|32,768 kHz|QCM-315_SMD|CM315|1| | | | |695-CM315D-32.7KEZFT| |300-8813-1-ND|0, | ||
Zeile 22: | Zeile 18: | ||
|D5|BAV70|Double Diode|SOT23|2|267-7467|0, | |D5|BAV70|Double Diode|SOT23|2|267-7467|0, | ||
|D6|BAV70|Double Diode|SOT23|.| | | | | | | | | | |D6|BAV70|Double Diode|SOT23|.| | | | | | | | | | ||
- | |D7|BAS85|Schottky barrier diode |SOD80C|3|146-9394|0, | + | |D7|BAS85|Schottky barrier diode|SOD80C|3|146-9394|0, |
|D8|BAS85|Schottky barrier diode|SOD80C|.| | | | | | | | | | |D8|BAS85|Schottky barrier diode|SOD80C|.| | | | | | | | | | ||
|D9|BAS85|Schottky barrier diode|SOD80C|.| | | | | | | | | | |D9|BAS85|Schottky barrier diode|SOD80C|.| | | | | | | | | | ||
Zeile 30: | Zeile 26: | ||
|D3|blue|LED|LED_3MM|1|276-4975|0, | |D3|blue|LED|LED_3MM|1|276-4975|0, | ||
|BAT1-HOLDER| |Battery Holder CR2032| |1|188-5903|2, | |BAT1-HOLDER| |Battery Holder CR2032| |1|188-5903|2, | ||
- | |BAT1|CR2032P_L|Lithium | + | |BAT1|CR2032P_L|Lithium Battery 3, |
|X1|PN87520-S|USB Plug HOST|PN87520-S|1|117-7883|0, | |X1|PN87520-S|USB Plug HOST|PN87520-S|1|117-7883|0, | ||
|J11|MINI-USB_B|USB Plug DFU|MINI-USB_B|1|211-2367|0, | |J11|MINI-USB_B|USB Plug DFU|MINI-USB_B|1|211-2367|0, | ||
Zeile 43: | Zeile 39: | ||
|R1B|0R|SMD Resistor TK50|0805|9| | |SMD-0805 0|0,02| | | | | | |R1B|0R|SMD Resistor TK50|0805|9| | |SMD-0805 0|0,02| | | | | | ||
|R2|1k|SMD Resistor TK50|0603|7| | |SMD-0603 1,0k|0,03| | | | | | |R2|1k|SMD Resistor TK50|0603|7| | |SMD-0603 1,0k|0,03| | | | | | ||
- | |R3|100R|SMD Resistor TK50|0603|2| | |SMD-0603 0|0,03| | | | | + | |R3|100R|SMD Resistor TK50|0603|2| | |SMD-0603 0|0,03| | | | | |
|R4|1k|SMD Resistor TK50|0603|.| | | | | | | | | | |R4|1k|SMD Resistor TK50|0603|.| | | | | | | | | | ||
|R4B1|2R2|SMD Resistor TK50|1206|4| | |SMD ¼W 2,2|0,03| | | | | | |R4B1|2R2|SMD Resistor TK50|1206|4| | |SMD ¼W 2,2|0,03| | | | | | ||
Zeile 111: | Zeile 107: | ||
|C8|470nF|SMD Chip Capacitor NP0/ | |C8|470nF|SMD Chip Capacitor NP0/ | ||
|C9|220uF|SMD Alu-Elko 16V low ESR|E_SMD_0608|6| | |VF 220/16 P-D8|0,3| | | | | | |C9|220uF|SMD Alu-Elko 16V low ESR|E_SMD_0608|6| | |VF 220/16 P-D8|0,3| | | | | | ||
- | |C10|100nF|SMD Chip Capacitor X7R|0603|62| | |X7R 0603FCF 100N|0,04| | | | | | + | |C10|100nF|SMD Chip Capacitor X7R|0603|61| | |X7R 0603FCF 100N|0,04| | | | | |
|C11|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | |C11|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | ||
- | |C12|10uF|SMD Tantal-ELKO 16V|TA-B | + | |C12|10uF|SMD Tantal-ELKO 16V|TA-B 3,5 x 2,8|9| | |T494B 10U 16|0,51| | | | | |
- | |C13|10uF|SMD Tantal-ELKO 16V|TA-B | + | |C13|10uF|SMD Tantal-ELKO 16V|TA-B 3,5 x 2,8|.| | | | | | | | | |
|C14|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | |C14|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | ||
|C15|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | |C15|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | ||
- | |C16|10uF|SMD Tantal-ELKO 16V|TA-B | + | |C16|10uF|SMD Tantal-ELKO 16V|TA-B 3,5 x 2,8|.| | | | | | | | | |
- | |C17|10uF|SMD Tantal-ELKO 16V|TA-B | + | |C17|10uF|SMD Tantal-ELKO 16V|TA-B 3,5 x 2,8|.| | | | | | | | | |
|C18|1uF|SMD Chip Capacitor NP0/ | |C18|1uF|SMD Chip Capacitor NP0/ | ||
|C19|1uF|SMD Chip Capacitor NP0/ | |C19|1uF|SMD Chip Capacitor NP0/ | ||
|C20|470nF|SMD Chip Capacitor NP0/ | |C20|470nF|SMD Chip Capacitor NP0/ | ||
|C21|1nF|SMD Chip Capacitor NP0/ | |C21|1nF|SMD Chip Capacitor NP0/ | ||
- | |C22|10uF|SMD Tantal-ELKO 16V|TA-B | + | |C22|10uF|SMD Tantal-ELKO 16V|TA-B 3,5 x 2,8|.| | | | | | | | | |
|C23|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | |C23|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | ||
- | |C24|4.7uF|SMD Tantal-ELKO |TA-A | + | |C24|4.7uF|SMD Tantal-ELKO|TA-A 3,2 x 1,6|1| | |T491A 4,7U 16|0,04| | | | | |
|C25|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | |C25|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | ||
|C26|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | |C26|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | ||
Zeile 143: | Zeile 139: | ||
|C39|220uF|SMD Tantal-ELKO 10V|TA-C|.| | | | | | | | | | |C39|220uF|SMD Tantal-ELKO 10V|TA-C|.| | | | | | | | | | ||
|C40|470nF|SMD Chip Capacitor NP0/ | |C40|470nF|SMD Chip Capacitor NP0/ | ||
- | |C41|10uF|SMD Tantal-ELKO 16V|TA-B | + | |C41|10uF|SMD Tantal-ELKO 16V|TA-B 3,5 x 2,8|.| | | | | | | | | |
|C42|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | |C42|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | ||
|C43|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | |C43|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | ||
Zeile 184: | Zeile 180: | ||
|C79|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | |C79|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | ||
|C80|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | |C80|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | ||
- | |C81|1uF |SMD Chip Capacitor NP0/ | + | |C81|1uF|SMD Chip Capacitor NP0/ |
|C82|1uF|SMD Chip Capacitor NP0/ | |C82|1uF|SMD Chip Capacitor NP0/ | ||
- | |C83|1uF |SMD Chip Capacitor NP0/ | + | |C83|1uF|SMD Chip Capacitor NP0/ |
|C84|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | |C84|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | ||
|C85|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | |C85|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | ||
Zeile 199: | Zeile 195: | ||
|C95|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | |C95|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | ||
|C96|220uF|SMD Alu-Elko 16V low ESR|E_SMD_0608|.| | | | | | | | | | |C96|220uF|SMD Alu-Elko 16V low ESR|E_SMD_0608|.| | | | | | | | | | ||
- | |C97|10uF|SMD Tantal-ELKO 16V|TA-B | + | |C97|10uF|SMD Tantal-ELKO 16V|TA-B 3,5 x 2,8|.| | | | | | | | | |
- | |C98|10uF|SMD Tantal-ELKO 16V|TA-B | + | |C98|10uF|SMD Tantal-ELKO 16V|TA-B 3,5 x 2,8|.| | | | | | | | | |
|C99|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | |C99|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | ||
+ | |C100|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | ||
|C101|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | |C101|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | ||
|C102|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | |C102|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | ||
Zeile 207: | Zeile 204: | ||
|C105|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | |C105|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | ||
|C106|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | |C106|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | ||
- | |C107|1uF |SMD Chip Capacitor NP0/ | + | |C107|1uF|SMD Chip Capacitor NP0/ |
|C108|1uF|SMD Chip Capacitor NP0/ | |C108|1uF|SMD Chip Capacitor NP0/ | ||
- | |C109|220pF|SMD Chip Capacitor NP0/ | + | |C109|220pF|SMD Chip Capacitor NP0/ |
- | |C111|10uF|SMD Tantal-ELKO 16V|TA-B | + | |C111|10uF|SMD Tantal-ELKO 16V|TA-B 3,5 x 2,8|.| | | | | | | | | |
|C112|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | |C112|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | ||
|C120|220uF|SMD Tantal-ELKO 10V|TA-C|.| | | | | | | | | | |C120|220uF|SMD Tantal-ELKO 10V|TA-C|.| | | | | | | | | | ||
Zeile 216: | Zeile 213: | ||
|C122|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | |C122|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | ||
|C123|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | |C123|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | | ||
- | |C124|8,2pF – 10pF|SMD Chip Capacitor|0603|2| | |NPO-G0603 10P |0,04| | | | | | + | |C124|8,2pF – 10pF|SMD Chip Capacitor|0603|2| | |NPO-G0603 10P|0,04| | | | | |
|C125|8,2pF – 10pF|SMD Chip Capacitor|0603|.| | | | | | | | | | |C125|8,2pF – 10pF|SMD Chip Capacitor|0603|.| | | | | | | | | | ||
- | |S1|G3|SMD Pushbutton KSC941J| |18|243-5157|0, | + | |S1|G3|SMD Pushbutton KSC941J| |19|243-5157|0, |
|S2|G2|SMD Pushbutton KSC941J| |.| | | | | | | | | | |S2|G2|SMD Pushbutton KSC941J| |.| | | | | | | | | | ||
|S3|M2|SMD Pushbutton KSC941J| |.| | | | | | | | | | |S3|M2|SMD Pushbutton KSC941J| |.| | | | | | | | | | ||
Zeile 237: | Zeile 234: | ||
|S17|Power|SMD Pushbutton KSC941J| |.| | | | | | | | | | |S17|Power|SMD Pushbutton KSC941J| |.| | | | | | | | | | ||
|S18|not assigned yet|SMD Pushbutton KSC941J| |.| | | | | | | | | | |S18|not assigned yet|SMD Pushbutton KSC941J| |.| | | | | | | | | | ||
+ | |S19|not assigned yet|SMD Pushbutton KSC941J| |.| | | | | | | | | | ||
|J1|1503_07|Audio Plug 3, | |J1|1503_07|Audio Plug 3, | ||
Zeile 249: | Zeile 247: | ||
| |Button Cap|Cap red|BTNKSC940|2| | | | | | |CKN10428-ND|0, | | |Button Cap|Cap red|BTNKSC940|2| | | | | | |CKN10428-ND|0, | ||
| |Button Cap|Cap black|BTNKSC990|2| | | | | | |CKN10426-ND|0, | | |Button Cap|Cap black|BTNKSC990|2| | | | | | |CKN10426-ND|0, | ||
- | | |Button Cap|Cap white|BTNKSC980|10| | | | | | |CKN10427-ND|0, | + | | |Button Cap|Cap white|BTNKSC980|11| | | | | | |CKN10427-ND|0, |
- | |JP1|30 Pin Board to Board|Pinheader-1X30|1X30|1| | |3x 40-polig| | | | | | | + | |JP1|30 Pin Board to Board|Pinheader-1×30|1×30|1| | |3x 40-polig| | | | | | |
- | |JP2|25 Pin Board to Board|Pinheader-1X25|1X25|1| | | | | | | | | | + | |JP2|25 Pin Board to Board|Pinheader-1×25|1×25|1| | | | | | | | | |
- | |JP3| 6 Pin Board to Board|Pinheader-1X06|1X06|4| | | | | | | | | | + | |JP3|6 Pin Board to Board|Pinheader-1×06|1×06|4| | | | | | | | | |
- | |P1|SW_12V|Pinheader-1X02|1X02|6| | | | | | | | | | + | |P1|SW_12V|Pinheader-1×02|1×02|6| | | | | | | | | |
- | |P2|Speaker left|Pinheader-1X02|1X02|.| | | | | | | | | | + | |P2|Speaker left|Pinheader-1×02|1×02|.| | | | | | | | | |
- | |P7|Speaker right|Pinheader-1X02|1X02|.| | | | | | | | | | + | |P7|Speaker right|Pinheader-1×02|1×02|.| | | | | | | | | |
- | |P6|DFU mode Jumper|Pinheader-1X02|1X02|.| | | | | | | | | | + | |P6|DFU mode Jumper|Pinheader-1×02|1×02|.| | | | | | | | | |
- | |JP8|DEBUG|Pinheader-1X06|1X06|.| | | | | | | | | | + | |JP8|DEBUG|Pinheader-1×06|1×06|.| | | | | | | | | |
- | |JP17|short S17|Pinheader-1X02|1X02|.| | | | | | | | | | + | |JP17|short S17|Pinheader-1×02|1×02|.| | | | | | | | | |
- | |JP5|ext. USB Host|Pinheader-1X04|1X04|2| | | | | | | | | | + | |JP5|ext. USB Host|Pinheader-1×04|1×04|2| | | | | | | | | |
- | |JP6|ext. USB DFU|Pinheader-1X04|1X04|.| | | | | | | | | | + | |JP6|ext. USB DFU|Pinheader-1×04|1×04|.| | | | | | | | | |
- | |JP4|ext. Audio|Pinheader-1X06|1X06|.| | | | | | | | | | + | |JP4|ext. Audio|Pinheader-1×06|1×06|.| | | | | | | | | |
- | |JP7|ext. Audio|Pinheader-1X06|1X06|.| | | | | | | | | | + | |JP7|ext. Audio|Pinheader-1×06|1×06|.| | | | | | | | | |
- | |P3|alternative Bridge Vbat|Pinheader-1X02|1X02|.| | | | | | | | | | + | |P3|alternative Bridge Vbat|Pinheader-1×02|1×02|.| | | | | | | | | |
- | |LCD1| |Pinheader-2x17|2x17|1| | | | | | | | | | + | |LCD1| |Pinheader-2×17|2×17|1| | | | | | | | | |
- | |LCD/PCB| |Holeheader low profile | + | |LCD/PCB| |Holeheader low profile |
|BU2|MOLEX_SD_49225-0821|MICROSD_Cardreader|Molex 503182-1853|1|176-4375|1, | |BU2|MOLEX_SD_49225-0821|MICROSD_Cardreader|Molex 503182-1853|1|176-4375|1, | ||
Zeile 275: | Zeile 273: | ||
|IC9|CY15B104Q|SPI FRAM|SO08| | | | | | | | | | | |IC9|CY15B104Q|SPI FRAM|SO08| | | | | | | | | | | ||
|IC11|SST25VF04B|SPI FLASH 2,7V, 4Mbit|SO08| | | |SST 25VF040B|0, | |IC11|SST25VF04B|SPI FLASH 2,7V, 4Mbit|SO08| | | |SST 25VF040B|0, | ||
