en:operations:uhsdrops
Differences
Link to this comparison view
Next revision
Previous revision
en:operations:uhsdrops [15.02.2018 15:58] – created df9tsen:operations:uhsdrops [17.02.2018 11:43] (current) – df9ts
Line 2: Line 2:
 ===== UHSDR Operations ===== ===== UHSDR Operations =====
-==== Reset all settings to defualt ====+==== Reset all settings to default ====
   * Switch off OVI40UI   * Switch off OVI40UI
   * Press and hold push buttons F1 F3 F5   * Press and hold push buttons F1 F3 F5
-  * Switch on OVI40, wait for text message, release F1 F F5+  * Switch on OVI40, wait for text message, release F1 F3 F5
   * Press simultaneously Band+ and Band- buttons to confirm resetting of settings   * Press simultaneously Band+ and Band- buttons to confirm resetting of settings
   * When UHSDR has bootet up long-press System Menu (F1 button) to save values   * When UHSDR has bootet up long-press System Menu (F1 button) to save values
 +Hint:
 +If you just want to play around with default setting without loosing your own configuration:
 +  * do NOT press MENU long
 +  * do NOT switch off via power button because that stores active settings to EEPROM - just pull off power supply.
  • en/operations/uhsdrops.1518710335.txt.gz
  • Last modified: 15.02.2018 15:58
  • by df9ts
