Differences
| Both sides previous revision Previous revision | |||
| en:ovi40build:displaybuild [25.04.2018 07:28] – [Display Calibration - mandatory at first bring-up] included post of Slawek df9ts | en:ovi40build:displaybuild [15.05.2018 13:18] (current) – [Display Assembly] df8oe | ||
| Line 69: | Line 69: | ||
| This pdf contains th modified assembly notes: {{: | This pdf contains th modified assembly notes: {{: | ||
| - | * C103 not needed anymore | + | * C103, C112, IC103 and R106 are not needed anymore |
| * R101 = R104 = 100K | * R101 = R104 = 100K | ||
| - | * R106 = 1K | ||
| * R102 = 15R | * R102 = 15R | ||
| + | * R105 = 3.3R | ||
| * all 10u now replaced by 1u | * all 10u now replaced by 1u | ||
| * XPT2046 = ADS7843E | * XPT2046 = ADS7843E | ||
| + | Put a small wire between pin3 and pin4 of IC103. Shorten R107 forever. | ||
| + | LCD can only work in parallel mode - there //will never be a SPI mode.// | ||
| DF8OE suggest to replace the two parallel tantal capacitors next to the 3.3V voltage regulator by 100nF & 1uF. He also suggest to put 100nF & 1uF in the free location shown in Andy's photo. | DF8OE suggest to replace the two parallel tantal capacitors next to the 3.3V voltage regulator by 100nF & 1uF. He also suggest to put 100nF & 1uF in the free location shown in Andy's photo. | ||
| Line 89: | Line 93: | ||
| Das Doppelklebeband links in voller Höhe (überdeckt die 20pol Löcher) in ca. 1cm Breite positionieren, | Das Doppelklebeband links in voller Höhe (überdeckt die 20pol Löcher) in ca. 1cm Breite positionieren, | ||
| ==== On shortening the male header J103 on OVI40 UI for LCD display ==== | ==== On shortening the male header J103 on OVI40 UI for LCD display ==== | ||
