en:projekte:ovi40-sdr:bom
Differences
Link to this comparison view
Next revision
Previous revision
en:projekte:ovi40-sdr:bom [07.02.2018 06:07] – df9ts_useren:projekte:ovi40-sdr:bom [11.03.2018 10:51] (current) – [UI-PCB:] yd0rwo
Line 32: Line 32:
 |D2|red|LED|LED_3MM|1|276-4977|0,361|LED 3MM ST RT| |710-151034RS03000| | | | |D2|red|LED|LED_3MM|1|276-4977|0,361|LED 3MM ST RT| |710-151034RS03000| | | |
 |D3|blue|LED|LED_3MM|1|276-4975|0,443|LED 3MM ST BL| |710-151034BS03000| | | | |D3|blue|LED|LED_3MM|1|276-4975|0,443|LED 3MM ST BL| |710-151034BS03000| | | |
-|BAT1-HOLDER| |Battery Holder CR2032| |1|188-5903|2,98| | | | |BU2032-1-ND|0,66|+|BAT1-HOLDER| |Battery Holder CR2032| |1|131-9749|2,98| | | | |BU2032-1-ND|0,66|
 |BAT1|CR2032P_L|Lithium Battery 3,0Volt|CR_2032_H|1| | |CR 2032P-H| | | | | | |BAT1|CR2032P_L|Lithium Battery 3,0Volt|CR_2032_H|1| | |CR 2032P-H| | | | | |
 |X1|PN87520-S|USB Plug HOST|PN87520-S|1|117-7883|0,81|USB AW|0,2| | | | | |X1|PN87520-S|USB Plug HOST|PN87520-S|1|117-7883|0,81|USB AW|0,2| | | | |
Line 242: Line 242:
 |S18|not assigned yet|SMD Pushbutton KSC941J| |.| | | | | | | | | |S18|not assigned yet|SMD Pushbutton KSC941J| |.| | | | | | | | |
-|J1|1503_07|Audio Plug 3,5mm|1503_07|3|121-7016|2,26|LUM 1503-07|0,59| | | | |+|J1|1503_07|Audio Plug 3,5mm|1503_07|3| |2,26|LUM 1503-07|0,59| | | | |
 |J2|1503_07|Audio Plug 3,5mm|1503_07|.| | | | | | | | | |J2|1503_07|Audio Plug 3,5mm|1503_07|.| | | | | | | | |
 |J3|1503_07|Audio Plug 3,5mm|1503_07|.| | | | | | | | | |J3|1503_07|Audio Plug 3,5mm|1503_07|.| | | | | | | | |
  • en/projekte/ovi40-sdr/bom.1517983677.txt.gz
  • Last modified: 07.02.2018 06:07
  • by df9ts_user
