en:uhsdr:uhsdrtroubleshooting
Differences
Link to this comparison view
Next revision
Previous revision
en:uhsdr:uhsdrtroubleshooting [12.02.2018 19:59] – df9tsen:uhsdr:uhsdrtroubleshooting [26.02.2018 18:58] (current) – df9ts_user
Line 43: Line 43:
 === 3. Debug cable === === 3. Debug cable ===
 The debug cable shouldn't be longer than 10 cm. 3 to 4 connections are needed. The debug cable shouldn't be longer than 10 cm. 3 to 4 connections are needed.
-|< 40% 33% 33% 33% >| +|< 60% 50% 25% 25% >|
-|  ST-link adapter  |  OVI40 UI JP8  | +|ST-link adapter  |OVI40 UI JP8  |Remark  |
-|Pin-13 TRACESWO  |JP8 Pin 1  |Debug Output  | +|Pin-13 TRACESWO  |JP8 Pin 1     |Debug Output  |
-|Pin-15 NRST      |JP8 Pin 2  |Reset         | +|Pin-15 NRST      |JP8 Pin 2     |Reset         |
-|Pin-07 SWDIO     |JP8 Pin 3  |Debug I/O     | +|Pin-07 SWDIO     |JP8 Pin 3     |Debug I/O     |
-|Pin-09 SWCLK     |JP8 Pin 4  |Debug Clock   | +|Pin-09 SWCLK     |JP8 Pin 4     |Debug Clock   |
-|Pin-01 MCU VDD   |JP8 Pin 5  |VDD from MCU  | +|Pin-01 MCU VDD   |JP8 Pin 5     |VDD from MCU  |
-|Pin-20 Gnd       |JP8 Pin 6  |Ground        |+|Pin-20 Gnd       |JP8 Pin 6     |Ground        |
 {{ :uhsdr:en.dm00026748.pdf |Beschreibung ST-Link V2 und ST-Link ISO Adapter, Pin out}} {{ :uhsdr:en.dm00026748.pdf |Beschreibung ST-Link V2 und ST-Link ISO Adapter, Pin out}}
Line 85: Line 85:
 4. If ok in SW tool click Target->MCU Core to display MCU option bytes.  4. If ok in SW tool click Target->MCU Core to display MCU option bytes.
 +[{{:uhsdr:optionbytes.png?400|Option Bytes values STM32F767ZI (screenshot DF9TS)}}]
 These are the correct values: These are the correct values:
  • en/uhsdr/uhsdrtroubleshooting.1518465560.txt.gz
  • Last modified: 12.02.2018 19:59
  • by df9ts
