Differences
Link to this comparison view
Next revision
Previous revision
en:uhsdr_dev:segger_j_link [18.02.2018 15:29] – [Install J-Link in GNU MCU Eclipse] df9tsen:uhsdr_dev:segger_j_link [27.02.2018 08:46] (current) df9ts_user
Line 1: Line 1:
-Segger Tools require a Segger probe to be used. For non-commercial use Segger offers the low priced "J-Link Eduprobe+==== Segger J-Link Introduction ====
 +Segger provides a probe - J-Link - that can be used for programming and debugging. For non-commercial use Segger offers the low priced [[https://www.segger.com/products/debug-probes/j-link/models/j-link-edu/|J-Link Edu]] probe.
 Segger supports the Cortex M7 SWV interface used on OVI40 UI and offers plug-ins for MCU eclipse. Segger supports the Cortex M7 SWV interface used on OVI40 UI and offers plug-ins for MCU eclipse.
-For Debug output Segger offers two options in MCU eclipse:+For Debug output Segger offers an two options in MCU eclipse:
   * TRACESWO output as defined by CORTEX M7. This requires a dedicated pin, currently used for M3 pushbutton switch   * TRACESWO output as defined by CORTEX M7. This requires a dedicated pin, currently used for M3 pushbutton switch
-  * Segger Real Time Tracing (RTT) with outputs debug messages in high speed via SWV debug lines (CLK and SWData). No need for an additional line to printout debug messages+  * [[https://www.segger.com/products/debug-probes/j-link/technology/real-time-transfer/about-real-time-transfer/|Segger Real Time Tracing (RTT)]] with outputs debug messages in high speed via SWV debug lines (CLK and SWData). No need for an additional line to printout debug messages (as is the case with TRACESWO).
 +The J-Link makes use of the Cortex-M feature, which allows accessing the memory via the debug interface while the target is running.
 +How this works in general is described [[https://www.segger.com/jlink-rtt.html|here]].
 The speed advantage of RTT - according to Segger data - is impressive: The speed advantage of RTT - according to Segger data - is impressive:
Line 13: Line 18:
 ==== Install J-Link Software ==== ==== Install J-Link Software ====
 === Debian SW Install === === Debian SW Install ===
   * Download .deb J-Link packages from [[http://www.segger.com/download_jlink.html|http://www.segger.com/download_jlink.html]]   * Download .deb J-Link packages from [[http://www.segger.com/download_jlink.html|http://www.segger.com/download_jlink.html]]
-  * Download J-link .deb file, open terminal and go to download folder with terminal<code>$ sudo dpkg -i nameofdebpackage.deb</code>+  * Download J-link .deb file, open terminal and go to download folder with terminal
 +<code>
 +$ sudo dpkg -i nameofdebpackage.deb
 +</code>
 === Windows SW Install === === Windows SW Install ===
 ToDo ToDo
 +==== Segger J-Link adapter Firmware update ====
 +As part of the Segger J-Link SW pack the "J-Link Configurator" utility. In Windows it can be started using the Windows start menu
 +[{{:en:uhsdr_dev:segger_config.png?400|Segger J-Link Configurator - Firmware update tool}}]
 ==== Install & Configure J-Link in GNU MCU Eclipse ==== ==== Install & Configure J-Link in GNU MCU Eclipse ====
Line 24: Line 42:
 See [[https://gnu-mcu-eclipse.github.io/debug/jlink/|here]] See [[https://gnu-mcu-eclipse.github.io/debug/jlink/|here]]
-==== Install Packs ====+=== Install Packs ===
 For installing CMSIS packs see [[https://gnu-mcu-eclipse.github.io/plugins/packs-manager/|here]] For installing CMSIS packs see [[https://gnu-mcu-eclipse.github.io/plugins/packs-manager/|here]]
-  * Install the GNU MCU Eclipse Packs  +
-  * Download CMSIS packs from Keil, see +  * Install the GNU MCU Eclipse Packs
 +  * Download CMSIS packs from Keil, see
   * Install local cop of STM32F7 and STM32H7   * Install local cop of STM32F7 and STM32H7
-==== J-Link and Eclipse ==== +=== J-Link and Eclipse ===
-  * Describe Eclipse seetings (MCU, CMSIS, probe settings, ...) to use J-link probe on Eclipse with uHSDR+
 +  * Describe Eclipse seetings (MCU, CMSIS, probe settings, ) to use J-link probe on Eclipse with uHSDR
 ==== Segger Real Time Terminal RTT ==== ==== Segger Real Time Terminal RTT ====
   * See [[https://wiki.segger.com/RTT|here]]   * See [[https://wiki.segger.com/RTT|here]]
-  * [[https://os.mbed.com/teams/anyThing-Connected/code/SEGGER_RTT/|Try RTT on UHSDR]] - is it really 100 times faster than SWO print and 10.000 times fasster than semi-hosting? Segger says [[https://wiki.segger.com/RTT|here]] that Cortex-M supports background memory access and that RTT will have no impact on Cortex-M execution speed +  * See {{:en:uhsdr_dev:an08005_usingrttoncortexar.pdf|AN08005}}  (although this is for Cortex-A / Cortex-R and not the Cortex-M used by OVI40 it still gives some insights)
- +  * [[https://os.mbed.com/teams/anyThing-Connected/code/SEGGER_RTT/|Try RTT on UHSDR]]
 + - is it really 100 times faster than SWO print and 10.000 times fasster than semi-hosting? Segger says [[https://wiki.segger.com/RTT|here]] that Cortex-M supports background memory access and that RTT will have no impact on Cortex-M execution speed
 +== RTT target code ==
 +The RTT target code is shipped as part of the J-Link Software and Documentation Pack which can be downloaded [[https://www.segger.com/products/debug-probes/j-link/technology/real-time-transfer/about-real-time-transfer/|here]]. The RTT sources can be found in the J-Link software package under: Samples/RTT
 +=== Calling SEGGER_RTT print from within interrupts / make it re-entrant ===
 +During RTT output the functions SEGGER_RTT_LOCK() and SEGGER_RTT_UNLOCK() are called by default in RTT, but the function bodies of those functions are empty and need to be implemented according to MCU used and use case.
 +Please implement
 +  * SEGGER_RTT_LOCK()
 +  * SEGGER_RTT_UNLOCK()
 +  * .. and disable interrupts and threads which might use RTT in SEGGER_RTT_LOCK() and enable them again in SEGGER_RTT_UNLOCK().
 +  * See [https://mcuoneclipse.com/2014/01/26/entercritical-and-exitcritical-why-things-are-failing-badly/|here]] for a discussion on how to enable / disable interrupts on Cortex-M
 ==== J-Link support for Option bytes and Lock / Unlock ==== ==== J-Link support for Option bytes and Lock / Unlock ====
 +Segger provides a "STM32 unlock" utility as part of the standard J-Link SW pack. The tool can be started in Windows using the "start" menue and resets all values to factory default:
 +[{{:en:uhsdr_dev:segger_stm32_unlock.png?400|Segger J-Link STM32 unlock utility}}]
 +**Note:**  The unlock utility resets the brown out reset (BOR) to "level 0", equalling about 1.7 Volt.
 +Further reading:
   * Check Option Byte support on J-Link, see [[https://wiki.segger.com/Setting_read_out_protection_on_STM32F0_devices|here]] and [[http://forum.segger.com/index.php?page=Thread&threadID=1486|here]] for a starting point.   * Check Option Byte support on J-Link, see [[https://wiki.segger.com/Setting_read_out_protection_on_STM32F0_devices|here]] and [[http://forum.segger.com/index.php?page=Thread&threadID=1486|here]] for a starting point.
   * See [[https://wiki.segger.com/STM32|here]] and [[https://wiki.segger.com/MCU_Security_Options|here]]   * See [[https://wiki.segger.com/STM32|here]] and [[https://wiki.segger.com/MCU_Security_Options|here]]
-  * See 3.12.2 J-Link STM32 Unlock (Command line tool) in {{ :en:uhsdr_dev:um08001_jlink.pdf |J-Link User Guide}} +  * See 3.12.2 J-Link STM32 Unlock (Command line tool) in {{:en:uhsdr_dev:um08001_jlink.pdf|J-Link User Guide}}
-  * J-Link adapter seems to support option byte programming via J-link utility and/or J-Flash utility. This is indicated in previous versions of the J-Link or J-Flash user guides, but not in the current ones. See for example section 7.5.1.2 [[http://www.farnell.com/datasheets/1512229.pdf|here]] +   * J-Link adapter seems to support option byte programming via J-link utility and/or J-Flash utility. This is indicated in previous versions of the J-Link or J-Flash user guides, but not in the current ones. See for example section 7.5.1.2  [[http://www.farnell.com/datasheets/1512229.pdf|here]]
-    * ToDo: Verify and try out +      * ToDo: Verify and try out
 +==== Flashing MCU with Segger J-Link ====
 +As part of the Segger J-Link SW pack the flash utility "J-Link lite" is provided. Start J-Flash using Windows "start" button. **Note:**  J-Flash does not support .dfu files. Use the UHSDR .bin files. Load bootloader at address 0x08000000 and load firmware at 0x08010000.
 +[{{:en:uhsdr_dev:j-flash.png?400|Segger J-Flash Lite tool}}]
 +==== Get to know J-Link: Converting on-board ST-Link On-Board into J-Link On-Board ====
 +  * Certain STM32 development boards contain an ST-Link probe.
 +  * For experiments with J-Link (not related to OVI40, but in order to get to know J-Link HW & SW) the on-board ST-Link board of those boars can be converted to J-Link, see [[https://www.segger.com/products/debug-probes/j-link/models/other-j-links/st-link-on-board/|here]].
 +  * Compatible STM32 that can be re-flashed are listed [[https://www.segger.com/products/debug-probes/j-link/models/other-j-links/st-link-on-board/|here]].
 ==== ToDo ==== ==== ToDo ====
-  * Checkout [[https://wiki.segger.com/STM32|Segger STM32 support Wiki]] in general+
 +  https://www.segger.com/products/debug-probes/j-link/models/other-j-links/st-link-on-board/Checkout [[https://wiki.segger.com/STM32|Segger STM32 support Wiki]] in general
 ==== Further Reading ==== ==== Further Reading ====
-  * {{ :en:uhsdr_dev:um08001_jlink.pdf |J-Link User Guide}}
-  * {{ :en:uhsdr_dev:um08003_jflash.pdf |J-Flash User Guide}}
 +  * {{:en:uhsdr_dev:um08001_jlink.pdf|J-Link User Guide}}
 +   * {{:en:uhsdr_dev:um08003_jflash.pdf|J-Flash User Guide}}
  • en/uhsdr_dev/segger_j_link.1518967748.txt.gz
  • Last modified: 18.02.2018 15:29
  • by df9ts
