en:uhsdr_dev:toolchain
Differences
Link to this comparison view
Next revision
Previous revision
en:uhsdr_dev:toolchain [02.02.2018 07:21] – df9ts_useren:uhsdr_dev:toolchain [06.02.2018 23:03] (current) – df9ts_user
Line 1: Line 1:
-{{tag>english}}{{tag>private}} +{{tag>english}}{{tag>review}}
-<bootnote warning>This page under construction - no guarantee what soever that content is correct, fit for use. Use at your own peril</bootnote>+<bootnote> Attention: Work in progress - page under construction</bootnote>
 ===== UHSDR development - toolchain for Debian ===== ===== UHSDR development - toolchain for Debian =====
Line 11: Line 11:
     * Eclipse     * Eclipse
     * Check installation with test project     * Check installation with test project
-Cloning UHSDR from Github, compiling and running (later)
 === GNU ARM toolchain for Linux === === GNU ARM toolchain for Linux ===
-<bootnote>Important: use ltest version of tool chain from web sites below. DO NOT use the ARM toolchain that comes with your Linux distribution</bootnote> +<bootnote>Important: use latest version of tool chain from web sites below. DO NOT use the ARM toolchain that comes with your Linux distribution</bootnote>
-<bootnote>Important: At the time of writing (Jan 2018) this gcc needs to be used: "gcc-arm-none-eabi-6-2017-q2-update-linux". The latest q4 version compiles UHSDR but the resulting UHSDR does not run. Under further investigation</bootnote>+
 See [[https://gnu-mcu-eclipse.github.io/toolchain/arm/install/]] for general explanations See [[https://gnu-mcu-eclipse.github.io/toolchain/arm/install/]] for general explanations
 === Install Arm toolchain for Linux === === Install Arm toolchain for Linux ===
-  * Download the latest Linux install tarball file from ARMDeveloper **(use Version 6-2017-q2-update, released: June 28, 2017)**+  * Download the latest Linux install tarball file from ARMDeveloper
   * Link to download: https://developer.arm.com/open-source/gnu-toolchain/gnu-rm/downloads   * Link to download: https://developer.arm.com/open-source/gnu-toolchain/gnu-rm/downloads
   * Assuming downloaded file is in /home/gerd/Downloads, open terminal with user gerd:   * Assuming downloaded file is in /home/gerd/Downloads, open terminal with user gerd:
Line 27: Line 24:
 $ mkdir -p ${HOME}/opt $ mkdir -p ${HOME}/opt
 $ cd ${HOME}/opt $ cd ${HOME}/opt
-$ tar xjf ~/Downloads/gcc-arm-none-eabi-6-2017-q2-update-linux.tar.bz2 +$ tar xjf ~/Downloads/gcc-arm-none-eabi-7-2017-q4-major-linux.tar.bz2
-$ chmod -R -w /home/gerd/opt/gcc-arm-none-eabi-6-2017-q2-update/+$ chmod -R -w /home/gerd/opt/gcc-arm-none-eabi-7-2017-q4-major/
 </code> </code>
   * Test if the compiler is functional; use the actual install path:   * Test if the compiler is functional; use the actual install path:
 <code> <code>
-$ /home/gerd/opt/gcc-arm-none-eabi-6-2017-q2-update//bin/arm-none-eabi-gcc-6.3.1 --version+$ /home/gerd/opt/gcc-arm-none-eabi-7-2017-q4-major/bin/arm-none-eabi-gcc-7.2.1 --version
 </code> </code>
   * Output should be like this:   * Output should be like this:
 <code> <code>
-arm-none-eabi-gcc-6.3.1 (GNU Tools for ARM Embedded Processors 6-2017-q2-update) 6.3.1 20170620 (release) [ARM/embedded-6-branch revision 249437] +arm-none-eabi-gcc-7.2.1 (GNU Tools for Arm Embedded Processors 7-2017-q4-major) 7.2.1 20170904 (release) [ARM/embedded-7-branch revision 255204]
-Copyright (C) 2016 Free Software Foundation, Inc.+Copyright (C) 2017 Free Software Foundation, Inc.
 This is free software; see the source for copying conditions.  There is NO This is free software; see the source for copying conditions.  There is NO
 warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Line 44: Line 41:
 === GDB - GNU Debugger & OpenOCD === === GDB - GNU Debugger & OpenOCD ===
-GDB 7.12 distributed with the initial GCC 6.2 (gcc-arm-none-eabi-6_2-2016q4-20161216) has several issues (crashes on macOS and is incompatible with Neon.2). +Check that GDB is installed in your Linux distribution by entering
-The recommendation is to use the update version gcc-arm-none-eabi-6-2017-q1-update, or later. +
-=== Install OpenOCD === +
-  * See [[https://gnu-mcu-eclipse.github.io/openocd/install/]] +
-  * Download from [[https://github.com/gnu-mcu-eclipse/openocd/releases]] +
-  * Latest version is gnu-mcu-eclipse-openocd-0.10.0-5-20171110-1117-debian64.tgz+
 <code> <code>
-$ sudo mkdir -p /opt/gnuarmeclipse +$ gdb
-$ cd /opt/gnuarmeclipse +
-$ tar xvf /home/gerd/Downloads/gnu-mcu-eclipse-openocd-0.10.0-5-20171110-1117-debian64.tgz +
 </code> </code>
-  * Test installation:+The output should look like this:
 <code> <code>
-$ /opt/gnuarmeclipse/gnu-mcu-eclipse/openocd/0.10.0-5-20171110-1117/bin/openocd --version+GNU gdb (Debian 7.12-6+b1) 7.12.0.20161007-git
 +Copyright (C) 2016 Free Software Foundation, Inc.
 +License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
 </code> </code>
-  * Output should be like this:+If missing install with
 +<code>
 +apt-get install gdb
 +</code>
 +  * Latest GNU MCU OpenOCD binaries can be found [[https://gnu-mcu-eclipse.github.io/openocd/releases/|here]].
 +  * This leads e.g. to [[https://github.com/gnu-mcu-eclipse/openocd/releases/tag/v0.10.0-7-20180123/|these binary files]]
 +Installation:
 +<code>
 +$ cd ${HOME}/opt
 +$ tar xvf ~/Downloads/gnu-mcu-eclipse-openocd-0.10.0-7-20180123-1217-centos64.tgz
 +$ chmod -R -w gnu-mcu-eclipse/openocd/0.10.0-7-20180123-1217
 +</code>
 +Check OpenOCD installation:
 +<code>
 +$ ${HOME}/opt/gnu-mcu-eclipse/openocd/0.10.0-7-20180123-1217/bin/openocd --version
 +</code>
 +Output should be something like this:
 <code> <code>
-GNU MCU Eclipse 64-bits Open On-Chip Debugger 0.10.0+dev-00254-g2ec04e4e (2017-11-10-11:27)+GNU MCU Eclipse 64-bits Open On-Chip Debugger 0.10.0+dev-00404-g20463c28 (2018-01-23-12:24)
 Licensed under GNU GPL v2 Licensed under GNU GPL v2
 For bug reports, read For bug reports, read
-http://openocd.org/doc/doxygen/bugs.html+ http://openocd.org/doc/doxygen/bugs.html
 </code> </code>
 +Install UDEV rules for USB OpenOCD probes:
 +<code>
 +# cp ${HOME}/opt/gnu-mcu-eclipse/openocd/0.10.0-7-20180123-1217/contrib/60-openocd.rules /etc/udev/rules.d/
 +# udevadm control --reload-rules
 +# usermod -aG plugdev $USER
 +</code>
 +Install OpenOCD Debugging plugin, see [[https://gnu-mcu-eclipse.github.io/openocd/install/|here]]
 +Update OpenOCD path, see [[https://gnu-mcu-eclipse.github.io/openocd/install/|here]]
 +{{ :en:uhsdr_dev:openocd.pdf |OpeOCD manual from sourceforge}} \\
 +[[https://community.particle.io/t/tutorial-using-eclipse-st-link-v2-openocd-to-debug/10042|eclipse & st-link/v2 tutorial]]
 +In Virtualbox make sure the STM-link/V2 adapter is connected through to virtual machine (check machine settings->USB)
 +In Eclipse hit green "Debug" button.
 === GNU MCU Eclipse and CDT === === GNU MCU Eclipse and CDT ===
   * Install Eclipse and CDT   * Install Eclipse and CDT
Line 80: Line 110:
 $ tar xvf /home/gerd/Downloads/20180125-1917-gnumcueclipse-4.3.2-oxygen-2-linux.gtk.x86_64.tar.gz  $ tar xvf /home/gerd/Downloads/20180125-1917-gnumcueclipse-4.3.2-oxygen-2-linux.gtk.x86_64.tar.gz
 </code> </code>
 +Make the GNU Arm toolchain location known to Eclipse in Project->Properties->C/C++ Build->Environment->PATH. add the path to GCC here (in this example we would add /home/gerd/opt/gcc-arm-none-eabi-7-2017-q4-major/bin ).
 === Launch Eclipse to test installation === === Launch Eclipse to test installation ===
Line 86: Line 118:
 /home/gerd/opt/GnuMcuEclipse/eclipse/eclipse  /home/gerd/opt/GnuMcuEclipse/eclipse/eclipse
 </code> </code>
-=== Install GNU MCU Eclipse plug-ins ===
-  * See https://gnu-mcu-eclipse.github.io/plugins/install/
-  * In Eclipse: Help->Install new software, choose "work with GNU MCU Eclipse Plug-ins - http://gnu-mcu-eclipse.netlify.com/v4-neon-updates". Then select these packages:
-    * GNU MCU C/C++ ARM Cross Compiler
-    * GNU MCU C/C++ Documentation (Placeholder)
-    * GNU MCU C/C++ OpenOCD Debugging
-    * (GNU MCU C/C++ QEMU) ??
-    * GNU MCU C/C++ STM32Fx Project Templates
 === Build Test Project to check all is ok === === Build Test Project to check all is ok ===
Line 100: Line 123:
 === Next step: import UHSDR into gnu arm eclipse === === Next step: import UHSDR into gnu arm eclipse ===
-[[en:uhsdr_dev:uhsdrimport|UHSDR development - import UHSDR into gnu arm eclipse]]+[[en:uhsdr_dev:uhsdrbuild|UHSDR development - import UHSDR into gnu arm eclipse]]
  • en/uhsdr_dev/toolchain.1517556101.txt.gz
  • Last modified: 02.02.2018 07:21
  • by df9ts_user
