Differences
Link to this comparison view
Next revision
Previous revision
en:uhsdr_dev:uhsdrbuild [12.02.2018 15:10] – df9tsen:uhsdr_dev:uhsdrbuild [15.02.2018 00:03] (current) – [Download new firmwar .bin to OVI40 UI] df9ts_user
Line 27: Line 27:
 Newly built binary fw-ovi40.bin can be found in the eclipse project explorer (left sidebar): mchf-eclipse -> DebugOVI40 -> fw-ovi40.bin Newly built binary fw-ovi40.bin can be found in the eclipse project explorer (left sidebar): mchf-eclipse -> DebugOVI40 -> fw-ovi40.bin
-==== Download new firmwar .bin to OVI40 UI ====+==== Download new firmware .bin to OVI40 UI ====
   * Please refer to [[https://www.amateurfunk-sulingen.de/wiki/doku.php?id=en:uhsdr:uhsdrfw#st-link_v2_firmware_upgrade]]   * Please refer to [[https://www.amateurfunk-sulingen.de/wiki/doku.php?id=en:uhsdr:uhsdrfw#st-link_v2_firmware_upgrade]]
   * UHSDR FW build should run.   * UHSDR FW build should run.
Line 49: Line 49:
 ==== Debug, tracing, real-time diagnostics ==== ==== Debug, tracing, real-time diagnostics ====
   * [[http://blog.atollic.com/learn-serial-wire-viewer-debugging-on-cortex-m|nice summary of Cortex M tools here]]   * [[http://blog.atollic.com/learn-serial-wire-viewer-debugging-on-cortex-m|nice summary of Cortex M tools here]]
 +  * [[https://gnu-mcu-eclipse.github.io/debug/openocd/|OpenOCD & Eclipse debug step-by-step instructions]]
 +  * {{:en:uhsdr_dev:en.dm00354244.pdf|AN4989 Application note STM32 microcontroller debug toolbox}}
 +  * Concurrent use of ST-Link debugger and SWO Viewer not possible, see [[http://www.openstm32.org/forumthread4122|here]] - but [[https://mcuoneclipse.com/2016/10/17/tutorial-using-single-wire-output-swo-with-arm-cortex-m-and-eclipse/|this]] link states Eclipse support in debugger for SWO?
 +  * J-Link Debug Probe [[:en:uhsdr_dev:segger_j_link|here]]
 ==== Further reading ==== ==== Further reading ====
   * https://www.amateurfunk-sulingen.de/forum/index.php?board=15;action=display;threadid=313;start=0   * https://www.amateurfunk-sulingen.de/forum/index.php?board=15;action=display;threadid=313;start=0
   * https://www.amateurfunk-sulingen.de/forum/index.php?board=15;action=display;threadid=263   * https://www.amateurfunk-sulingen.de/forum/index.php?board=15;action=display;threadid=263
 +  * SWV and SWO and Eclipse explaind [[https://mcuoneclipse.com/2016/10/17/tutorial-using-single-wire-output-swo-with-arm-cortex-m-and-eclipse/| here]]
  • en/uhsdr_dev/uhsdrbuild.1518448249.txt.gz
  • Last modified: 12.02.2018 15:10
  • by df9ts
