en:uhsdr_dev:win10_toolchain
Differences
Link to this comparison view
Next revision
Previous revision
en:uhsdr_dev:win10_toolchain [25.02.2018 09:10] – df9ts_useren:uhsdr_dev:win10_toolchain [13.03.2018 09:34] (current) – [Using Git with GNU-MCU-Eclipse] corrected scrambled formatting df9ts_user
Line 6: Line 6:
       * Install and test       * Install and test
   * Gnu Arm toolchain from here, Win32 exe  [[https://developer.arm.com/open-source/gnu-toolchain/gnu-rm/downloads|https://developer.arm.com/open-source/gnu-toolchain/gnu-rm/downloads]]   * Gnu Arm toolchain from here, Win32 exe  [[https://developer.arm.com/open-source/gnu-toolchain/gnu-rm/downloads|https://developer.arm.com/open-source/gnu-toolchain/gnu-rm/downloads]]
-      * Execute downloaded file. Tick "add to path". +      * Execute downloaded file. Tick "add to path".
       * Installs in C:\Program Files (x86)\GNU Tools ARM Embedded\7 2017-q4-major       * Installs in C:\Program Files (x86)\GNU Tools ARM Embedded\7 2017-q4-major
       * See [[https://gnu-mcu-eclipse.github.io/toolchain/arm/install/|https://gnu-mcu-eclipse.github.io/toolchain/arm/install/]]       * See [[https://gnu-mcu-eclipse.github.io/toolchain/arm/install/|https://gnu-mcu-eclipse.github.io/toolchain/arm/install/]]
Line 39: Line 39:
       * Will install in C:\Program Files\GNU ARM Eclipse\QEMU\2.8.0-201612271623-dev       * Will install in C:\Program Files\GNU ARM Eclipse\QEMU\2.8.0-201612271623-dev
   * Get latest MCU Eclipse from here  [[https://github.com/gnu-mcu-eclipse/org.eclipse.epp.packages/releases/|https://github.com/gnu-mcu-eclipse/org.eclipse.epp.packages/releases/]]   * Get latest MCU Eclipse from here  [[https://github.com/gnu-mcu-eclipse/org.eclipse.epp.packages/releases/|https://github.com/gnu-mcu-eclipse/org.eclipse.epp.packages/releases/]]
-      * Extract downloaded zip file to c:\ (otherwise path names may become too long)+      * Extract downloaded zip file to c: (otherwise path names may become too long)
   * Run GNU MCU Eclipse   * Run GNU MCU Eclipse
       * Follow work space preferences "global tool chain path" in [[https://gnu-mcu-eclipse.github.io/eclipse/workspace/preferences/|https://gnu-mcu-eclipse.github.io/eclipse/workspace/preferences/]]       * Follow work space preferences "global tool chain path" in [[https://gnu-mcu-eclipse.github.io/eclipse/workspace/preferences/|https://gnu-mcu-eclipse.github.io/eclipse/workspace/preferences/]]
Line 68: Line 68:
         * For OVI40 with H7 MCU: Project → Properties → C/C++ Build → Settings → Devices → STM32H743ZI         * For OVI40 with H7 MCU: Project → Properties → C/C++ Build → Settings → Devices → STM32H743ZI
-Using Git with GNU-MCU-Eclipse+==== Check for updates ====
 +  * in Eclipse Help→check for updates
 +==== Using Git with GNU-MCU-Eclipse ====
 +=== Option: Github Desktop ===
   * Download Github desktop from [[https://desktop.github.com/|https://desktop.github.com/]]   * Download Github desktop from [[https://desktop.github.com/|https://desktop.github.com/]]
-  * Start Github Desktop, enter your Githu username and password, clone repository "https://github.com/df8oe/UHSDR" * Optional: create local branch of cloned repo for tests * In Eclipse, create new workspace pointing to local clone of cloned Github UHSDR repository * Check Eclipse settings for * active build config * MCU device used * … //+  * Start Github Desktop, enter your Githu username and password, clone repository "https://github.com/df8oe/UHSDR"
 +  * Optional: create local branch of cloned repo for tests
 +  * In Eclipse, create new workspace pointing to local clone of cloned Github UHSDR repository
 +  * Check Eclipse settings for
 +    * active build config
 +    * MCU device used * …
 +=== Option: git commandline ===
 +  * create directory where UHSDR repository should reside, e.g. d:\uhsdr''git clone  https://github.com/df8oe/UHSDR  ''
 +=== Import git UHSDR project into Eclipse installation ===
 +  * In Eclipse, choose “File→Import”.
 +  * .. then choose “General→Existing Projects into Workspace”.
 +  * Then choose the folder “mchf-eclipse in the path where you just downloaded the zip file as “root-directory”
 +  * The project is now recognized and can be imported * Next: check Eclipse settings
  • en/uhsdr_dev/win10_toolchain.1519549857.txt.gz
  • Last modified: 25.02.2018 09:10
  • by df9ts_user
