fr:uhsdr:uhsdrbl
Différences
Prochaine révision
Révision précédente
fr:uhsdr:uhsdrbl [10.02.2018 21:42] – df9ts_userfr:uhsdr:uhsdrbl [13.02.2018 16:49] (Version actuelle) – [Option 3: Mise à jour boot loader par clé USB] df9ts
Ligne 57: Ligne 57:
 ToDo ToDo
-=== Preconditions ===+=== Préconditions ===
-  * Download latest bl-40SDR.dfu bootloader from [[https://www.amateurfunk-sulingen.de/uhsdr/bootloader-latest/OVI40/|here]]. +  * Téléchargez le dernier bl-40SDR.dfu "boot loader" d'[[https://www.amateurfunk-sulingen.de/uhsdr/bootloader-latest/OVI40/|ici]].
-  * Install ST-Micro DeFuse Tool: [[http://www.st.com/en/development-tools/stsw-stm32080.html|http://www.st.com/en/development-tools/stsw-stm32080.html]] +  * Installez l'outil PC ST-Micro DeFuse Tool: [[http://www.st.com/en/development-tools/stsw-stm32080.html|http://www.st.com/en/development-tools/stsw-stm32080.html]]
-  * Connect PC with OVI40 UI via USB - to - MiniUSB cable. Use MiniUSB plug on OVI40 UI +  * Connectez le PC avec OVI40 UI via cable USB-MiniUSB. Utilisez la petite prise MiniUSB sur le OVI40 UI
-  * ST-Micro DFuse SW installed on PC and running, USB drivers installed, OVI40 UI recognized by PC +  * Outil ST-Micro DFuse installé sur PC qui fonctionne corretement, USB drivers / pilotes USB installés, OVI40 UI reconu par PC comme appareil USB
-  * OVI40 UI powered up with 5V (JP1)+  * OVI40 UI alimenté avec +5V (JP1)
 === Procedure === === Procedure ===
-  * Boot loader installation described {{:projekte:ovi40-sdr:bootloader_install.pdf|here}}+  * Installation "boot loader" est décrit {{:projekte:ovi40-sdr:bootloader_install.pdf|ici}}
-=== Further reading ===+=== Documentation supplémentaire ===
   * {{:uhsdr:en.cd00155676.pdf|ST-Micro DFuse Tool description}}   * {{:uhsdr:en.cd00155676.pdf|ST-Micro DFuse Tool description}}
    * [[http://www.st.com/content/st_com/en/products/development-tools/software-development-tools/stm32-software-development-tools/stm32-programmers/stsw-stm32080.html|DfuSe Ressources and SW (bootom of page)]]    * [[http://www.st.com/content/st_com/en/products/development-tools/software-development-tools/stm32-software-development-tools/stm32-programmers/stsw-stm32080.html|DfuSe Ressources and SW (bootom of page)]]
-==== Option 3: USB-Stick upgrade upgrade ====+==== Option 3: Mise à jour "boot loader" par clé USB ====
 ToDo ToDo
-  * Download latest bl-40SDR.bin bootloader from [[https://www.amateurfunk-sulingen.de/uhsdr/bootloader-latest/OVI40/|here]]. +  * Téléchargez le plus récent bl-40SDR.bin "boot loader" d'[[https://www.amateurfunk-sulingen.de/uhsdr/bootloader-latest/OVI40/|ici]].
-  * Format USB-Stick with FAT file partition. MAke sure - just in case - that USB-stick is otherwise empty +  * Formattez la clé USB avec FAT ou FAT32
-  * Copy .bin file to stick. Make sure it is copied as file, not just a link / short-cut +  * Copiez fichier .bin sur clé USB. Vérifiez que le fichier a été copier et non pas seulement un raccourci
-  * OVI40 UI powered up with 5V (Pin 28 JP1) and 8V (Pin 29 JP1) and GND (Pin 30 JP1). The 8V powers the USB stick via voltage regulator +  * OVI40 UI alimenté avec +5V (Pin 28 JP1) et +8V (Pin 29 JP1) et terre (Pin 30 JP1). Les +8V sont l'alimentation pour la clé USB
-  * Recent UHSDR boot loader installed and working+  * "Boot loader" UHSDR récent installé et en état de marche
-=== Procedure ===+=== Procédure ===
 +  * Mettez +8V à JP1 pin 29 - pour alimenter la clé USB
 +  * Appuyez et restez appuyé sur la touche "BAND -"
 +  * Alimenté +5V à JP1 pin 28 - cela pour démarrer le "boot loader" installé
 +  * insérez la clé USB dans la prise USB large du OVI40 UI
 +  * Attendez que le upload soit fini
 +  * Relachez la touche "Band -"
 +  * Enlevez, puis remettez +5V pour redémarrer le OVI40 UI
 +  * Vérifiez le bon fonctionnement
 +[{{:uhsdr:i40_32.jpg?400|Mise à jour du "boot loader" avec clé USB (photo DL8EBD)}}]
 +==== Vérifiez le bon fonctionnement du "boot loader" ====
-  - Supply +8V on JP1 pin 29 - to pwer USB stick +Retirez le cavalier P6 s'il a été précédemment mis, puis démarrez le OVI40 UI
-  - Push and - important - hold switch "BAND -" +
-  - Supply +5V on JP1 pin 28 - this starts the boot loader +
-  - insert USB stick into large USB port of OVI40 UI +
-  - Wait for FW upload to finish +
-  - Release switch "Band -" +
-  - Remove +5V, then apply again to reboot OVI40 UI.+
-==== Check proper working of newly loaded boot loader ====+Au démarge aun "boot loader" correctement installé va afficher un texte similaire a celui là:
-Remove Jumper P6 if previously closed, then boot UI.+[{{:uhsdr:i40_33.jpg?400|Boot loader splash screen au démarrage du OVI40 UI}}]
-Check boot loader version number displayed in system menu corresponds to the version you intended to install.+Vérifiez aussi que le numéro de version "boot loader" affiché dans le menu système correspond à la version que vous avez installé.
-===== UHSDR Bootloader further reading =====+===== Documents supplémentaires =====
 Forum: Forum:
  • fr/uhsdr/uhsdrbl.1518298957.txt.gz
  • Dernière modification : 10.02.2018 21:42
  • de df9ts_user
