ovi40wiki:wikitodo
Nächste Überarbeitung
ovi40wiki:wikitodo [07.02.2018 22:01] – [Wiki Howto] df9tsovi40wiki:wikitodo [19.02.2018 13:37] (aktuell) – alte Version wiederhergestellt (15.02.2018 07:11) df9ts
Zeile 1: Zeile 1:
-{{tag>german}}{{tag>stub}} +{{tag>german}}{{tag>publish}}
-===== Wiki Howto =====+
 +===== Wiki ToDo =====
   * Check why Discussion cannot be switched off per page   * Check why Discussion cannot be switched off per page
   * Try to disable translation outdated warning   * Try to disable translation outdated warning
Zeile 11: Zeile 12:
     * http://www.ov-selbstbau.de/doku.php?id=de:projects:pro_tut_6:pro_tut_6     * http://www.ov-selbstbau.de/doku.php?id=de:projects:pro_tut_6:pro_tut_6
   * Align German and English versions of [[:ovi40test:uiboardtest]]   * Align German and English versions of [[:ovi40test:uiboardtest]]
-  * Do multinamespace pages for toolchain etc., following WikiTodo example with plugin:include
   * Check tags used actually, compare with page overview for gaps   * Check tags used actually, compare with page overview for gaps
-  * Change page UI-Platine to use one namespace and include - remove germanenglish tag +  * In uhsdr:uhsdrtroubleshooting complete debug cable with trace output TRACESWO
 +  * Implement language detection https://www.dokuwiki.org/tips:browserlanguagedetection - use browser language detection to automatically to switch to en fr de (the languages currently used in wiki) all other should go to English?
 +  * Add STM32 device signatures for F7 H7 and F4 used https://www.amateurfunk-sulingen.de/forum/index.php?board=18;action=display;threadid=1025;start=0#lastPost
 ==== Stub Seiten - diese Seiten müssen noch erstellt werden ==== ==== Stub Seiten - diese Seiten müssen noch erstellt werden ====
Zeile 28: Zeile 29:
 {{topic>publish nofirsthl&tags&date&nouser&table}} {{topic>publish nofirsthl&tags&date&nouser&table}}
 +====Include Seiten ====
 +{{topic>include nofirsthl&tags&date&nouser&table}}
 +==== Autogenerate Seiten ====
 +{{topic>autogenerate nofirsthl&tags&date&nouser&table}}
  • ovi40wiki/wikitodo.1518040883.txt.gz
  • Zuletzt geändert: 07.02.2018 22:01
  • von df9ts
